Low Range - BEEP!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO 1, Aug 21, 2009.
  1. Aug 21, 2009 at 10:47 AM
    TACO 1
    TACO 1 [OP] Senior Member
    Jim
    Washington State
    09 DCab Taco TRD
    Matching topper, wheels & tires, running boards, bull bar & lights, 3" lift
    It drives me nuts to listen to the beep beep beep when I have my rig in low range. Why did Toyota do that???
  2. Aug 21, 2009 at 10:49 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Its not in Low range. The beeping is telling you its not engauged.
  3. Aug 21, 2009 at 10:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What he said.
    OP-Did you read the manual before trying to engage 4LO?? You need to have the truck completely stopped (MT-Clutch to the floor AT-In neutral) then turn the knob and see what happens. A little bit of reverse or side to side wheel turns may also help.
    Reading the manual is key tho-
  4. Aug 21, 2009 at 10:53 AM
    TACO 1
    Jim
    Washington State
    09 DCab Taco TRD
    looks like a service call.... I'm in low range and it beeps.
  5. Aug 21, 2009 at 10:53 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    yup you gotta put it in neutral before it will stop beeping
  6. Aug 21, 2009 at 10:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Is the light on steady??
  7. Aug 21, 2009 at 10:59 AM
    TACO 1
    Jim
    Washington State
    09 DCab Taco TRD
    yep....
  8. Aug 21, 2009 at 11:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Hrmp....that's a new one. Service sounds like the way to go...a 09 shouldn't be any trouble to get warranty coverage...I'd try the neutral thing like was suggested above tho....
  9. Aug 21, 2009 at 11:04 AM
    TACO 1
    Jim
    Washington State
    09 DCab Taco TRD
    I think so too. I'll try the other things also, but it's probably a bad switch or sensor.....
  10. Aug 21, 2009 at 11:05 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Definitely take it in. Are both hubs locked in I wonder?
  11. Aug 21, 2009 at 11:30 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    You have to let it fully engage in 4Hi before you go to 4Lo. I get in a hurry sometimes and don't let thie first one fully engage before going to the second and get the annoying beep.
  12. Aug 21, 2009 at 11:41 AM
    TACO 1
    Jim
    Washington State
    09 DCab Taco TRD
    Thanks to all for your input.
    Jim H.
  13. Aug 21, 2009 at 11:44 AM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    if you have manual transmission its best if your totally stopped, press the clutch in all the way down, while holding down the clutch then switch it in to 4 hi, then turn it again and put it in Lo, release the clutch and you should be good to go
  14. Aug 21, 2009 at 1:18 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Is the "4lo" light staying on solid or blinking? Not the green 4X4 light, but the yellow 4lo light.
  15. Aug 21, 2009 at 1:46 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Man I miss the Lever actuated transfer in my 99 taco...
  16. May 8, 2012 at 3:22 PM
    HZUNI
    HZUNI New Member
    T or C NM
    08 Tacoma 4X4
    I'll try all the suggestions.
    Thanks
  17. Jun 8, 2012 at 12:42 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yup, me too. This 2012 it never has yet gone into 4lo the first time. I have to put the clutch in, flip the switch to 4lo from 4hi, listen to it beep and flash, then release the clutch, put the clutch back in, flip it to 4hi, then back to 4lo. And voila! Finally kicks into 4lo.
    And going from 4lo back to 4hi same thing.
    And from 2wd to 4hi (and back) isn't much better. I really shouldn't have to keep flipping that switch back and forth at times. I really dislike the auto xfer case, how is this an improvement?
  18. Jun 8, 2012 at 1:41 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Three year old thread resurrection.
    I've never had a problem with an auto t-case. I've had them on an F-150, my Tacoma, and my patrol Colorado. The only issue with the Colorado is you have to be MOVING at 2mph or less, in neutral, before it will switch into or out of 4 Low without grinding. Not a problem with the truck either, it's how you're supposed to do it.
  19. Jun 8, 2012 at 2:14 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    Going from RWD to 4HI is painless enough for me. Flip the switch and drive.
    But 4LO is finicky. When they say stopped, they mean dead stop - not even rocking on the suspension. And the clutch to the floor means all the way to the floor. Not that half assed kinda sorta pushed in that gets the job done every other time you use it.
  20. Jun 8, 2012 at 2:16 PM
    monkeyface
    Colorado
    Eh, I just had to bitch, moan and lament the sure action of the manual transfer case vs. the auto xfer case's spotty action.
    Are you saying you surely go into the drive position you want to first-time and every time? I haven't got that feeling from the posts I've read here.
