Low speed brake shudder 2018 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mikesixtysix, Mar 17, 2018.
  1. Mar 17, 2018 at 2:53 PM
    mikesixtysix
    mikesixtysix [OP] Well-Known Member
    North Jersey
    2018 TRD Pro
    I've only got 300 miles on this beast, but I noticed immediately that when I brake I can feel a shudder or pulsing around 10mph until I stop. It has the feeling of warped rotors, and the harder I brake, the more noticeable it is. This can't be normal, I'm hoping :)
  2. Mar 17, 2018 at 3:12 PM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
  3. Mar 17, 2018 at 5:37 PM
    mikesixtysix
    North Jersey
    2018 TRD Pro
  4. Mar 17, 2018 at 6:54 PM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Yea 18 off-road here.. thought I saw that somewhere and I have that issue
    mikesixtysix[OP] likes this.
  5. Mar 17, 2018 at 7:00 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    You might need to bed the pads. You possibly have some uneven pad material on the rotor face being that new.
  6. Mar 18, 2018 at 7:56 AM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Mine is at 3500mi and still has the issue. I'll talk to dealer about it on 5k service... I have a fairly good dealer near me.
  7. Apr 7, 2018 at 2:06 PM
    mikesixtysix
    North Jersey
    2018 TRD Pro
    At 550 miles now, and it's just getting worse... my fillings rattle when I hit the brakes. Bringing it in to the dealer on Tuesday.
    shakerhood likes this.
  8. Apr 7, 2018 at 2:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Someone had a Thread up about Warped Drums and Bent Axles, could possibly be causing your issue too.
    Cl4aub and mikesixtysix[OP] like this.
  9. Apr 7, 2018 at 3:46 PM
    Ryandr91
    Ryandr91 Well-Known Member
    Corpus Christi, TX
    2018 Cavalry Blue Pro
    I think I have this same issue. I plan to bring it up at 5K service as well. Only seems to happen when slowly coming to a complete stop.
  10. Apr 10, 2018 at 7:34 PM
    mikesixtysix
    North Jersey
    2018 TRD Pro
    Brought it in to the dealer where I bought it, only 547 miles on the clock. From the work order: Found front rotors out of round - used on car brake lathe and resurfaced front rotors.
    I told them that I'd expect the rotors to be replaced on a brand new vehicle that was delivered this way, but was told that this is Toyota policy and they would not replace rotors unless they were already worn out. :rolleyes:
  11. Jun 6, 2018 at 6:43 AM
    spinpuppy
    spinpuppy New Member
    Gitch
    2018 TRD Sport crew cab SB 6 SP Auto
    yep, same issue. I brought it in, service department said " thats normal for these trucks" also have a jerking feel when cruising at about 50 mph, when you just are maintaining speed. doesnt cruise smooth. Yall having that problem also?
  12. Jun 6, 2018 at 9:19 PM
    tlansdell
    tlansdell Member
    2018 Tacoma TRD Sport
    I have the same issue on my 2018 taco. In dealer now. They initially found a front brake pad that had fallen apart, but I took it for a drive after they completed this work and no change so far. Any suggestions? Seems to shudder just before coming to a stop. braking at higher speeds is super smooth
  13. Jun 6, 2018 at 9:26 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Mine does this as well. Noticed it with less than 100 miles. At 1,000 now, problem hasn't progressed. Been apprehensive to take to the dealer. I believe it may be the warped axle issue as shakerhood mentioned above. I wanted them to be in the know on the tsb, then I was going to bring it up to see if that's what I've got going on.
  14. Jun 6, 2018 at 9:55 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Seems like a warped axle would shudder or thud without using your brakes as well. I would start with the brakes.
  15. Jun 7, 2018 at 9:05 PM
    tlansdell
    tlansdell Member
    Changed out rear drums and put new pads on front discs. Issue still is present. I am leaning towards the TSB for the wrong drive shaft angle. As I was driving the vehicle away I tried coasting to a stop without using my breaks and could detect vibration around the same speed. I have a 2018..Does anyone know if the TSB will apply to 2018 models?
  16. Jun 8, 2018 at 8:46 AM
    Pecos bill
    Pecos bill Member
    I have the same problem took to the dealer 2 times still have the problem
  17. Jun 8, 2018 at 8:47 AM
    Pecos bill
    Pecos bill Member
    My is 2018 with 3100 miles
  18. Jun 8, 2018 at 8:48 AM
    Pecos bill
    Pecos bill Member
    I am very disappointed for a $40 k truck
    leggett334 and ddettamanti like this.
  19. Jun 8, 2018 at 8:49 AM
    toyotatacomaTRD
    They'll fix it. Mention the warped axle tsb. It's on here somewhere. See if that's your issue.
  20. Jun 8, 2018 at 7:35 PM
    tlansdell
    tlansdell Member
    I am actually thinking that it is the driveline angle and i believe the fix is to install new leaf springs to change the angle so that the driveshaft doesn't vibrate. Any other 2018 owners having vibration when coming to a stop around 0-20 mph?
