low tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barry J, Dec 13, 2011.
  1. Jan 4, 2012 at 6:19 PM
    00Jimmy00
    00Jimmy00 Well-Known Member
    Long Island
    08 SupWht OR
    Sorry, I failed to mention that I am upgrading tires and wheels from 265 70 16 to 285/70/17
  2. Jan 4, 2012 at 6:54 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The psi at max load capacity is just that...the maximum. If those tires were on a heavier truck with a heavy load in the bed the psi would need to be adjusted higher to handle the extra weight. Since the Tacoma is a light truck you need to be somewhere around 30-36psi at no-load. My tires (e rated bfg a/t's) have a max psi of 80psi. With the weight of a canopy the chalk test shows I need to be 36psi front/ 34 back.
  3. Jan 5, 2012 at 5:55 AM
    00Jimmy00
    Long Island
    08 SupWht OR
    ORtoy, Thats a good bit of info. I always inflated my tires 7-10lbs below max load pressure. I will definitly do the "chalk test" on these new tires. Do you usually perform the test after driving and heating up the tires or when cold? My guess is hot because you always have an increase in air pressure as the tire warms up and you drive more with heated tires than not.
    thx 00
  4. Jan 5, 2012 at 10:21 AM
    OffroadToy
    good read...
    http://www.nitrogentiremachine.com/proper_tire_inflation.htm
