Low voltage cut out/alarm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gus87, Jul 18, 2019.
  1. Jul 18, 2019 at 2:13 PM
    Gus87
    Gus87 [OP] Well-Known Member
    Chicagoland
    16 trd sport
    Maybe this is a stupid question maybe not. let's see. So I swore I've read on here about low voltage shut offs or disconnects where when your battery drops to low will shut off all the power. I've tried to search for it on here and the internet but I haven't came across anything that looked like what I was looking for. ( I also don't know what I'm looking for either) maybe I'm phrasing it wrong. When I Google "low voltage cutoff" I see these little boxes but I can't see how that would work. Do I the that into a solenoid or something? Any comments would be helpful.
  2. Jul 18, 2019 at 3:21 PM
    11DBJR
    11DBJR Well-Known Member
    JR
    O'side, CA
    2011 4x4 Access Cab 6-speed manual
    I think I get what you're saying and I agree it's difficult to properly spell it out, but something like this?:
    https://www.amazon.com/PriorityStart-12-Volt-Pro-SP-Automatic-Battery-Protector/dp/B0030A10V0
    You're looking for something that cuts off the battery from accessories and such before you lose the ability to start the vehicle?
    While I'm still planning my second battery to handle stuff like that, maybe it's more appropriate to have a good jumper battery pack when you get this low. I know that doesn't answer the question entirely, but something to consider.
    And that Amazon link was an example. There already weren't that many good reviews about it!
    Or are you looking for the factory option to do that? Like does your Taco shut off power to things before it gets too low?
    J.R.
  3. Jul 18, 2019 at 4:16 PM
    Gus87
    Chicagoland
    16 trd sport
    What you described first is exactly what I was thinking about. I had thought about a jumper pack as well. I plan to get one. I have a optima yellow currently. I had a red top before in a different car that had a short in it and it took forever to jump it. Long story short, I heard that once optimas are discharged they are hard to recover. I rather prevent a problem than be stranded and out of luck.
  4. Jul 19, 2019 at 5:24 AM
    Gus87
    Chicagoland
    16 trd sport
    I was looking those up last night and that really seems to be the only type there is. The reviews aren't so great on it either.
  5. Jul 19, 2019 at 12:19 PM
    sealfab
    sealfab Well-Known Member
    North Virginia
    2006 DCSB TRD
    Well I was going to recommend one but long live https://mp3car.com/ (not worth clicking), they used to sell a pretty cool device that would let you set a low voltage threshold and when that was crossed it could either drop power to your device or cycle a relay.
  6. Jul 19, 2019 at 12:53 PM
    Gus87
    Chicagoland
    16 trd sport
    I came across a blue sea one that looked more dependable. It is a timer and a low voltage cut off you can choose. The voltage cut off can be adjusted in .5 Increments. Like 12.5, 12, 11.5, 11. Idk if 11.5 is too low though.
    SR-71A likes this.
  7. Jul 19, 2019 at 3:35 PM
    sealfab
    North Virginia
    2006 DCSB TRD
  8. Jul 22, 2019 at 4:51 AM
    sealfab
    North Virginia
    2006 DCSB TRD
  9. Jul 22, 2019 at 7:00 AM
    Gus87
    Chicagoland
    16 trd sport
    I’ve came across ones like that but in order for that to work in my application would I need to tie it into a solenoid to trigger it off when the voltage drops too low?
  10. Jul 22, 2019 at 7:39 AM
    sealfab
    North Virginia
    2006 DCSB TRD
    Couldent the output of this cycle a relay that activates your solenoid?
  11. Jul 22, 2019 at 8:03 AM
    Gus87
    Chicagoland
    16 trd sport
    That’s what I was kind of asking. I don’t know how I would have to wire it if I went with something like this. Well I could probably figure out how to wire it I just don’t know all the parts I would need.
  12. Jul 22, 2019 at 8:15 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  13. Jul 22, 2019 at 8:49 AM
    sealfab
    North Virginia
    2006 DCSB TRD
