Low4x4 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roadkiller, Oct 7, 2010.
  1. Oct 7, 2010 at 6:36 AM
    roadkiller
    roadkiller [OP] Member
    Quebec , Canada
    Trd Sport 07 Tac
    almost stock
    I have a 07 tacoma, when I put it on Low4x4 and I turn right or left, my steering and all the direction shake a lot and doesn't seems to like it at all... Is it normal ? I think my rear Diff is allways lock ,it's doing like my old Suzuki Sidekick that I have weld the rear diff for more fun and traction ... Can you clarify my idea ?? newbie...:p
  2. Oct 7, 2010 at 6:40 AM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    are you trying this on pavement? if so, stop
  3. Oct 7, 2010 at 7:26 AM
    roadkiller
    Quebec , Canada
    Trd Sport 07 Tac
    almost stock
    on 0-3/4 gravel
  4. Oct 7, 2010 at 7:38 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    4 wheel drive always understeers, and 4lo is going to be worse than 4hi. Gravel is relatively high traction surface as "off road" surfaces go. Sounds normal, especially if you're turning to full lock.
    Just to make sure the locker isn't engaged,try cycling it and check your gauge cluster icons to see if it goes on and off.
    I highly doubt the locker is stuck on all the time...if so, steering would be difficulty in two high on pavement and you'd be *shredding* your rear tires.
  5. Oct 7, 2010 at 8:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    In 4lo or 4hi ....you don't want to make sharp turns, it puts too much stress on the CV joints.
    Each situation/terrain is different and the steering will act differently in higher traction areas (pavement, dirt) versus lower traction areas (mud, ice). You just have to learn your limits for each situation. If you make turns & apply the gas at the same time (throttle through the turn) is where you'll have most problems and it'll vary 'how tight' of a turn you can make before the truck starts hopping, bucking, or won't move at all. Don't force it!!!
  6. Oct 7, 2010 at 9:04 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If your tires can't turn easily because traction is too high, then stay in 2WD.
    Once tires slip from snow, mud, ice, rain, sand on or off the road then 4WD High should be engaged... steering will not be a problem if you are moving.
    If you are not driving, but instead trying to move your truck into a parking spot, for example... even off road, 4WD is difficult because the front ane rear tires are locked together at the transfer case... return to 2WD for tight turning into a parking spot.
    4WD LOW is for severe poor traction, like deep snow, deep mud, steep grades, slow crawling with maximum power.
    The rear locker is the traction device of last choice... Only use it to get out of a stuck or for very poor traction hill climbs. The RR Locker light will go from blinking to solid when it is engaged (just like the 4WD lights do).
  7. Oct 7, 2010 at 9:14 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I don't think 4LO is suitable for severe poor traction, but more for obligatory slow crawling situations. In low traction situations I want more control over wheel spinning so 4HI. Both 4LO is more fun :)
  8. Oct 7, 2010 at 9:35 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Great advice! I also make wider turns in 4WD...especeally 4LO. Plan your turns ahead of time!
  9. Oct 7, 2010 at 9:38 AM
    roadkiller
    Quebec , Canada
    Trd Sport 07 Tac
    almost stock
    I don't have switch RR locker , Auto lsd or Rear diff lock in the truck ... when I says that I was thinkin that my rear diff was allways lock , I was in 2wd only . thats why I suppose that is allways lock .. You know what I mean ? I search my anglish word alot ...
  10. Oct 7, 2010 at 9:41 AM
    jandrews
    ...If you have a TRD Offroad 2nd Gen Tacoma, you have a locking rear diff and should have a switch in the dash.
    If you don't have a switch in the dash...something's fishy. Hope you didn't get caught purchasing an SR5 that just had offroad stickers slapped on it...
  11. Oct 7, 2010 at 9:42 AM
    fsbrain03
    fsbrain03 Well-Known Member
    Sucks for you!
  12. Oct 7, 2010 at 9:58 AM
    roadkiller
    Quebec , Canada
    Trd Sport 07 Tac
    almost stock
    I don't think so... Its a real trd off road with the 4 bilsteins shocks ,the hood , front and rear bumper painted and all the things who got a trd off-road...
  13. Oct 7, 2010 at 10:04 AM
    OffroadToy
    4X4 Offroad
    Sounds like the Sport model if the bumpers are painted. Are your door handles painted and does the hood have a scoop? Is the front grill chrome or painted? All 2nd Generation Offroad Models have the rear locker.
  14. Oct 7, 2010 at 10:09 AM
    Janster
    Jandy
    Lancaster, PA
    Sounds more like a TRD Sport with the mechanical LSD.
    Look at your rear differential. Does it have a sticker on it that says something like "LSD oil only"?? (can't remember exactly what it says)
  15. Oct 7, 2010 at 10:25 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Sport model for sure.
  16. Oct 7, 2010 at 10:40 AM
    roadkiller
    Quebec , Canada
    Trd Sport 07 Tac
    almost stock
    you gone laugh a lot at me guys... its not TRD off road stickers on my truck ... its TRD Sport !!! Im so shame right now... my truck is not a trd off road but a trd Sport .... Im so angry at me... So my rear end is an LSD diff with no locker... is this doing good jobe in mud and snow ? is this the same bilstein shock thats on trd off road?
  17. Oct 7, 2010 at 2:08 PM
    Janster
    Jandy
    Lancaster, PA
    Bingo!!
    The mechanical LSD is better than an open diff. I love mine for winter driving.
  18. Oct 7, 2010 at 2:36 PM
    David K
    Well, glad he figured it out... Sport has the fake hood scoop, first indicator! Next Toyota, get the Off Road so you have increased traction abilities!
