Lower ball joint failure
Discussion in 'New Members' started by 2000tacobro, May 1, 2015.
  1. May 1, 2015 at 1:06 AM
    2000tacobro
    2000tacobro [OP] Well-Known Member
    Houston , texas
    2014 Trd OR 4x4
    trd pro grill
    My lower ball joint fell out the cuppler and my lca hit the pavement Luckily I was in chick fil a drive thru . Has anyone else has this issue .its at "the shop" in Fremont , ca . Anyone have any good/bad to say about them
  2. May 5, 2015 at 9:29 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Stumbled across this, wrong forum but it's cool. There's a recall on lbj's you can see if you qualify. Other than that it's an easy fix. Four bolts ands the top nut. Take ya an hour or so. Search the forums or go into suspension forum and look. Lots of write ups. Go Toyota lbj's, they are the best quality and you don't want that to happen on the freeway...
