Lower ball joints brand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Holy schmidt, Aug 24, 2014.
  1. Feb 27, 2020 at 9:35 PM
    #61
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The way I read her original post, it may not be the ball joints at all. She might have a loose shock.
    I only say this because I have a loose shock, and it definitely makes unsettling noises when going over bumps.
  2. Feb 28, 2020 at 3:21 AM
    #62
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    1997 Toyota Tacoma Extended cab 2.4, RWD
    Trying to keep it in shape and running nicely.
    I was afraid to go with OEM because of the recall and I was not involved in buying them when it was a work truck but after this happened I wanted to make sure that I am the one buying safe quality part or parts.
    If someone else reads this and does not cheap out they can avoid damage or at the every least a tow.
    cruiserguy[QUOTED] likes this.
  3. Feb 28, 2020 at 3:35 AM
    #63
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    Oh yea I have had the truck in my family close to 20 years so I heard all about it.
    cruiserguy likes this.
  4. Feb 28, 2020 at 4:10 AM
    #64
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You're okay. I know exactly what you're saying. Some others don't quite get it, and they always know better, right? :rolleyes: You're family experience the last couple decades with the ball joints are exactly why I only recommend OEM. People do what they want, but you need to know the best part for longevity, that's the OEM. The OEM one will be youR best chance as it's superior in construction. The crap ones, folks get anywhere from 5k miles to 40k miles. The OEM ones last considerably longer. They're far better made. Nobody can deny that much. If they go off on some strawman argument, just nod politely and say thanks for your opinion and go buy the OEM one. :rofl:
    You may here more BS further here, I hope not. There was a recall years ago. The sumitomo plant that makes the OEM ball joints had an issue in their production of the part. But that was all corrected years ago.
    You will be happy with the OEM ball joint :D
    CS_AR likes this.
  5. Feb 28, 2020 at 1:32 PM
    #65
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Just wanted to add this here... I recently replaced both of my lower ball joints with some Moog parts off Amazon ( i know I know) but I was pleasantly surprised when they arrived with the 555 Stamp.
    Passing this along to other Tacoma drivers. At the time of this post, they were $40 a side. Way beefy and made in Japan. $20 per side cheaper than lowrange
    https://www.amazon.com/gp/product/B000C560V6/ref=as_li_tl?ie=UTF8
    https://www.amazon.com/gp/product/B000C545CC/ref=as_li_tl?ie=UTF8
  6. Feb 28, 2020 at 1:33 PM
    #66
    Wulf
    Wulf no brain just damage
    rock raisin
  7. Feb 28, 2020 at 1:34 PM
    #67
    OneWheelPeel
    Phoenix, AZ
    Big step in the right direction after replacing my AC Delco chinese parts
  8. Feb 28, 2020 at 1:36 PM
    #68
    eon_blue
    Azusa, CA
    I would agree lol. I don't see a problem with it as long as they're checked regularly. Which a person should do even with OEM ones
    jbrandt and OneWheelPeel[QUOTED] like this.
  9. Feb 28, 2020 at 1:49 PM
    #69
    0xDEADBEEF
    Got the same from advance auto. No problems so far.
    OneWheelPeel[QUOTED] likes this.
  10. Feb 28, 2020 at 1:49 PM
    #70
    OneWheelPeel
    Phoenix, AZ
    Were they the actual Moog boxed ones ?
  11. Feb 28, 2020 at 1:50 PM
    #71
    0xDEADBEEF
    Yep. Moog boxes on the outside, 555 on the inside.
  12. Feb 28, 2020 at 1:51 PM
    #72
    OneWheelPeel
    Phoenix, AZ
    Thats good to hear! I rush delivered mine from Amazon and was quite surprised when I saw the 555 logo. Even more surprised in how different they were from the AC Delcos I took off. Much thicker metal.
  13. Feb 28, 2020 at 1:54 PM
    #73
    0xDEADBEEF
    Yeah I was looking for something localish, since I had places to be and realized that there was a slight possibility that mine were original, and had 200,000 mi on them. I had to drive across town to get them in stock, but they had them.
  14. Feb 28, 2020 at 2:04 PM
    #74
    eon_blue
    Azusa, CA
    There has been someone that did just that, it's in another LBJ thread on here. Basically he confirmed that the OEM LBJs had the best quality, I'll see if I can find it
    High Noon likes this.
  15. Feb 28, 2020 at 2:08 PM
    #75
    eon_blue
    Azusa, CA
    There's way too many lower ball joint threads lol. Hopefully someone else remembers it too and knows which thread that info was in where the guy showed a few different brands cross sectioned. I remember something about how the OEM ball joint sort of 'floats' in the socket and doesn't make contact with the socket like the other brands do which makes them more likely to fail over time, or something like that
    That being said, for a daily driver I don't think there's anything inherently wrong with 555 lower ball joints, as long you check them regularly. For a truck that sees some abuse, I would stick with OEM. Don't want to have to worry more than normal about a failure on the trail or somewhere remote
    OneWheelPeel likes this.
  16. Feb 28, 2020 at 3:34 PM
    #76
    eon_blue
    Azusa, CA
  17. Feb 28, 2020 at 4:12 PM
    #77
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    From what I understand, 555 makes many of the different BJs. IIRC, I remember people saying they've gotten OEM ones with 555 stamped on them.
    Same manufacturer doesn't mean same quality, though. Even if they come off the same factory assembly line, they could be put in different boxes based on the outcome of QA checks. higher tolerances get OEM boxes, etc... They don't throw any of that stuff away, they just sell the crapier stuff under some other name for less money.
    0xDEADBEEF[QUOTED] likes this.
  18. Feb 28, 2020 at 4:22 PM
    #78
    0xDEADBEEF
    Maybe, maybe not. It might be more of a pain in the rear to manage multiple products and make sure they get sold to the right people than it would be just to melt them down and try again. I don't know how that particular sausage is made. But its easy enough to just keep an eye on the ones I've got that I'm not going to worry about it.
    As long as they last more than 25k or so, they'll be well ahead of my old chevy :laughing:
  19. Feb 28, 2020 at 4:24 PM
    #79
    jbrandt
    Justin
    I'm not aware there was a recall for the 5 lugs. The recall was for the 6 lugs, afaik. So you should be good to go there.
    The main problem with the 6 lug balljoints wasn't a Q/A issue (the stated reason for the recall), per say. It really stems from a design flaw, and how the ball/cup is under tension, rather than compression. The Q/A issues Toyota had with the early 6 lug BJs just compounded that and made it worse. So when/if a balljoint were to wear out and fail, it does so catastrophically vs. a "normal" design just getting loose.
    In the end there's no getting around the design flaw of the 6 lug balljoints, no matter what brand you get. Only way to get around it is to convert to uniballs and that's like serious coin and fabrication, off-road/long travel stuff.
    But again, since you're a 5 lug, you have an entirely different design that doesn't suck.
  20. Feb 28, 2020 at 4:31 PM
    #80
    0xDEADBEEF
    Of course, there's also an entirely different animal too - counterfeit parts. It could very well be the actual japanese sankei 555 parts are just fine, but there's also a factory in China cranking out identical looking but lesser quality ones. I've run into that with electronic parts. It sucks.
