Lower ball joints for 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by JakesTacoTRD, Dec 30, 2018.
  1. Dec 30, 2018 at 6:36 AM
    JakesTacoTRD
    JakesTacoTRD [OP] "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    My lower ball joints are leaking and I want to check if the part numbers 4334039436 (L) and 4333039556 (R) were the correct numbers for a 2001 Tacoma 3.4 4x4 manual. The dealer gave me these numbers but with a “5” at the end. Not sure if there is a difference with 4x4 and 2x4, but I appreciate the help.
    Best,
    Jacob
  2. Dec 30, 2018 at 6:44 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
  3. Dec 30, 2018 at 6:52 AM
    JakesTacoTRD
    Jacob
    Gainesville, FL
  4. Dec 30, 2018 at 7:04 AM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Was looking at these and then just go to my Stealership for the bolts. B5D8BD33-DD99-4293-B209-B03C3ABE63D5.jpg
  5. Dec 30, 2018 at 7:04 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    No clue but they fit perfect on mine.
    JakesTacoTRD [OP] likes this.
  6. Dec 30, 2018 at 7:07 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Check with your vin on this website http://www.toyodiy.com/parts/q.html it will give you parts specific to your truck. I guess those could be an alternate p/n but I’d verify before buying.
    QMEDJoe and JakesTacoTRD [OP] like this.
  7. Dec 30, 2018 at 7:31 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
  8. Dec 30, 2018 at 7:32 AM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Seems that the numbers are correct as with “5” at the end. Maybe the “6” was after the recall... says the “6” is to replace the one with the “5” on ToyotaofDallas. Guess I’ll buy that one and Thanks for your help
    DW85 likes this.
  9. Dec 30, 2018 at 7:55 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
  10. Dec 30, 2018 at 9:15 AM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Neither Camelback nor Dallas will process my order currently (maybe because they aren’t open on weekends), but from my vin and the new part numbers for those parts... this is what the numbers are...
    Lower ball joints: (x1 ea)
    (L): 4334039435 (old #) —> 4334039436(new #)
    (R): 4333039555 (old #) —> 433039556(new #)
    Bolts for Lower ball joint: (x8) 9010510406(old #) —> 9008010066(new #)
    Also the 4wd and prerunner have the same part number so it may not matter but use the like above to use your own link. Haven’t installed and will update after I do.
    Hope this helps someone in the future.
  11. Dec 31, 2018 at 8:51 AM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    My 99 Toyota ball joints came with bolts, rubber cap and everything complete. I think in years after they sold them separate.
  12. Jan 1, 2019 at 9:25 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Just submit your VIN if you order from Toyota Dallas. They will check the numbers for you. I deal with them all the time...
  13. Jan 1, 2019 at 11:08 AM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    I got the lower ball joints from them. Lowest prices I could find. Gonna get the tie rods at my dealership so they get to me a little sooner
  14. Jan 1, 2019 at 1:30 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
