Lower ball joints?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SouthernYoder, Feb 20, 2017.
  1. Feb 21, 2017 at 1:44 PM
    #41
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    First, to avoid confusion all the years have a different left and right joint.
    At some vague point, 02-03ish Toyota added a "protector" skirt and these joints were secured with the bolt/washer. When you look up these later joints the price is lower than the earlier joints because Toyota decided to not include the hardware pack that comes with the earlier year joints. The earlier joints used the flange head bolt. Again the joints themselves are the same across the board. The protector is just a rubber shroud.
    The hardware pack consisted of the 4 mount bolts, the castle nut and a brand new cotter pin.
    Go to an online Toyota vendor, look up a 99 4wd left side joint, now look up an 04 4wd left side joint. They are different #'s and prices. The cheaper 04 does not come with any hardware. The more expensive 99 comes with the hardware. The joints themselves are the same.
    And that's all I have to say about that.
    F. Gump out
    1stgenlurker and 99SuperTaco4x4 like this.
  2. Feb 21, 2017 at 1:53 PM
    #42
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    oem ball joints are the same 99.5-04. The different toyota part numbers corresponds to LBJs that come with the bolts vs. LBJs without the bolts. I bought the bolts and the LBJs that came with the bolts, which resulted in me having an extra set.
    Post above explains it better.
    edit:
    with new bolts: 43330-39815 and 43340-39585
    without new bolts: 43340-39436 and 43330-39556
    TWJLee and ThunderOne like this.
  3. Feb 21, 2017 at 1:56 PM
    #43
    Dirty Pool
    99 XCAB V6 MT TRD
    So I just went and checked my work and see 04 joints listed at Camelback with the early/late price difference between LEFT AND RIGHT sides. Gotta be a misprint.
  4. Feb 21, 2017 at 7:50 PM
    #44
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So if you wanted to get the joints *with* the hardware pack, even if you have an 04, would it be wise to get the 99 joints?
  5. Feb 22, 2017 at 3:21 AM
    #45
    MysticGold04
    MysticGold04 Active Member
    Thanks for the info provided.
    I called 2 of the dealerships that sell online and got conflicting info. They did not agree on part numbers, and the prices were wildly different. Both have different prices for right and left.
    I expected the installation to be the difficult part, not getting the right parts.
    Can anyone recommend a reliable (but fairly priced) source?
  6. Feb 22, 2017 at 4:30 AM
    #46
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Did you try Toyota of Dallas or camelback?
  7. Feb 22, 2017 at 6:51 AM
    #47
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Beat to death topic but I'll put my .02 in. I used Napa chassis ball joints, cv axles and tie rods. Been on there for about 35k. My pickup is my daily driver. lifted and I mildly off-road. They still look great and perform well. As soon as they break though I'll send pics! ;)
    Roadeater and SouthernYoder[OP] like this.
  8. Feb 22, 2017 at 7:44 AM
    #48
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    Everywhere I looked had different prices for the right and left as well, sometimes as much as $20. I have no explanation for that, it's bizarre.
    I buy a lot of stuff through Conicelli. They have a sale going on right now too, might save you a couple of bucks.
  9. Feb 22, 2017 at 8:11 AM
    #49
    Dirty Pool
    99 XCAB V6 MT TRD
    You most certainly could. Here comes the but. You would have to do away with the "protector" skirt as it uses the washer/bolt and I believe the bolt is longer to compensate for the thickness of the washer and protector. Frankly I would rather not have that skirt in place. I would prefer the more solid "bolt up" without the washer and skirt sandwiched under the bolt and the skirt makes it tough to see/inspect/check the joint. I am sure Toyota had some reason to add it but I have never seen brush or anything else damage the boot that the protector is supposed to protect.
    Further, I have spent all my life pulling skirts off.
    I got slapped alot but made out pretty good in the long run.;)
    cruiserguy likes this.
  10. Feb 22, 2017 at 8:20 AM
    #50
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    LOL! Yeah I noticed the last time mine were replaced they no longer had the skirt. So I'll probably just go ahead and order the 99 so the bolts are already included.
  11. Feb 22, 2017 at 8:25 AM
    #51
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Ozzy_Wuz_Here and SlipperyTaco like this.
  12. Feb 22, 2017 at 8:27 AM
    #52
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
  13. Feb 22, 2017 at 8:49 AM
    #53
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Looks like i'm gonna replace mine almost at 90k miles and they are leaky.
  14. Feb 22, 2017 at 9:09 AM
    #54
    Timmah!
    Timmah! Well-Known Member
    TIM
    Mash away my friend. I'm pretty quick with the pullers these days since I've used them so much now, so we're talking a savings of a few minutes. I was at a Pick and Pull recently raping a wrecked 3rd Gen and I tried the Ol' Hammer technique on the outer tie rod and it wouldn't budge. I pounded the shit out of it mashed up the knuckle of the balljoint pretty good. Pullers work every time.
    On my buddy Sean's rig, It's obvious the gorilla working on his truck used the hammer technique to break free the upper balljoint from the UCA. He bent the shit out of it. I used a long arm puller recently for the same application installing Total Chaos UCAs for a friend and it popped it free easily.
    But, to each his own. Use whatever technique that floats your boat.
    99SuperTaco4x4 likes this.
  15. Feb 22, 2017 at 9:24 AM
    #55
    TheSaint
    Mark
    Prescott, Arizona
    When I ordered mine they came without skirts or bolts. I reused the skirts that were already on there. I believe the addition of the skirt was part of the remedy for the LBJ recall that took place in 2005, but I could be wrong about that.
  16. Feb 22, 2017 at 9:28 AM
    #56
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    if that were the case then I would surmise that they would still be using them. But they aren't. Did you order the 2004 LBJs?
  17. Feb 22, 2017 at 9:38 AM
    #57
    Dirty Pool
    99 XCAB V6 MT TRD
    The skirt started to show up when the 1st gens were still in production. It is one of those deals where there is no clear documented point of introduction (as of yet). But it was in the last few production years.
  18. Feb 22, 2017 at 9:50 AM
    #58
    TheSaint
    Mark
    Prescott, Arizona
    43330-39556 and 43340-39436, latest part numbers from Toyota.
    Well, there you go. I just know that mine had the LBJs replaced under the recall, and since everyone else was saying theirs didn't have the skirts, I figured that was part of the recall. I guess they just reinstalled the skirts when they installed the recall LBJs.
  19. Feb 22, 2017 at 2:58 PM
    #59
    SlipperyTaco
    Chandler, AZ
    I was just told by toyota of dallas that these parts would be everything complete for both sides. and that cotter pins and protector lower balls come with the ball joints.
    Part Number: 43340-39436
    Part Number: 43330-39556
    Part Number: 90119-10933 x8
  20. Feb 22, 2017 at 3:00 PM
    #60
    99SuperTaco4x4
    And 8 bolts (your cart shows only 4)
