Lower bumper light bar wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheFlyTaco, Feb 10, 2021.
  1. Feb 10, 2021 at 5:09 PM
    TheFlyTaco
    TheFlyTaco [OP] Active Member
    Wow....this is so helpful! I really appreciate the thorough explanation. Any normal relay will work? Do you have a link for one?
  2. Feb 10, 2021 at 5:14 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Feb 10, 2021 at 5:31 PM
    TheFlyTaco
  4. Feb 10, 2021 at 7:22 PM
    caribe makaira
    Another option:
    Battery-fuse-Relay (pin#30 proper wire gauge for added light//18 gauge to tie in from pin#30 to pin#86)
    Relay pin #87 to added light
    Relay pin #85 to cab switch with 18 gauge wire.
    Cab switch needs to be SPDT (Single Pole Double Throw).
    On switch center pin from relay pin #85.
    Remaining top and bottom pins on switch = Chassis Ground on one, the other to C11, Steering Stalk Light Switch connector, pin #14.
    Switch provides ON at anytime. OFF. And ON with High beams.
    bagleboy, Grossomotto and PiñonTaco like this.
  5. Feb 11, 2021 at 4:55 AM
    TheFlyTaco
    Understood. I do not want to cut into existing wires. I'll find a relay and try your original option. Any certain amperage for the relay? 4 pin correct?
    Something like this?
    https://www.amazon.com/gp/product/B01NBH4IVV/ref=ox_sc_act_title_1?smid=A36ZH2MCHPKXUA&psc=1
  6. Feb 11, 2021 at 8:30 AM
    caribe makaira
    Yes, just make sure it's light bar amp appropriate. You never mentioned which Cali light bar your getting.
  7. Feb 11, 2021 at 1:36 PM
    TheFlyTaco
  8. Feb 11, 2021 at 4:49 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  9. Feb 11, 2021 at 5:28 PM
    TheFlyTaco
    300W 3k lumen but no amp or volt detail.
  10. Feb 11, 2021 at 6:01 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    300watts divided by 12 volts is 25 amps.
  11. Feb 11, 2021 at 6:23 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s ok to use bigger wire than you need(just more expensive). It’s not ok to use a bigger fuse than the wire is rated for. The fuse is to protect the wire so the fuse should be at or below the wire rating. Wires don’t generally fail unless grossly undersized but even before failure there is a loss of voltage from wire heating and lower light output so it’s best to use the right size. Cheap connectors are more likely to be a problem. Cases in point, the 3rd gen heated seat module connectors and 2nd gen blower motor resistor connectors.
    I use this page for choosing wire.
    https://www.powerstream.com/Wire_Size.htm
    Going by it for chassis wiring either #12 with up to a 30A fuse(25A ok too) or
    #14 with a 25A fuse.
    The voltage drop for 10’ of wire would be about .6v for #14 and .4v for #12. (Count both positive and negative wire lengths).
    Make sure the connectors you use are rated at 25A or more.
