lower control arm bushings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dakotaking81, Nov 1, 2009.
  1. Aug 19, 2016 at 9:49 AM
    #41
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Thread revival, but did you need to purchase new alignment hardware when you bought the LCAs? AKA do the moog LCAs come with the alignment hardware that needs to be cut off the existing setup?
  2. Aug 19, 2016 at 12:33 PM
    #42
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    Yeah I did. I would recomend buying all 4 cams and bolts and return what you don't need. I ended up needed it half way through and had to settle for some no name cam bolt I dont really trust
  3. Aug 19, 2016 at 1:11 PM
    #43
    Pigpen
    Dan
    Northwest Montana
    Go with OEM, not MOOG
  4. Aug 19, 2016 at 1:19 PM
    #44
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    I just priced out bushings & related hardware from the dealership actually.
    $700. No fucking way lol.
    If there's something better than Moog that's cheaper than OEM let me know.
    Why not Moog?
  5. Aug 19, 2016 at 1:26 PM
    #45
    Pigpen
    Dan
    Northwest Montana
