Lower control arm questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dl1998, Oct 29, 2024.
  1. Oct 29, 2024 at 4:16 PM
    Dl1998
    Dl1998 [OP] Member
    So after finaly driving the truck I've been building I've noticed it pulls super hard to the driver side when I hit the break .. rolled out as a work control arm bushing but will a warn control arm bushing cause your camber to be off on one side
  2. Oct 29, 2024 at 9:09 PM
    ciaman96
    ciaman96 Well-Known Member
    Tucson
    2001 Reg Cab Tacoma 4x4
    OME Lift, E-locker, interior swap
    My upper control arm bushings were horribly worn and it made quite a difference in steering feel and directness when I finally replaced them.
    That being said, mine didn’t pull hard under braking. Not sure if you did any work recently, but I’d check into the alignment and brakes as well.
