Lower Control Arm Replacement
Discussion in 'Suspension' started by hardground, Apr 26, 2016.
  1. Apr 26, 2016 at 7:04 PM
    hardground
    hardground [OP] Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    What stock brand LCA's are good?
    My bushings are starting to crack so I am just going to replace the whole LCA.
    The Total Chaos LCA's won't fit with the OME shocks that I have already ordered.
  2. Apr 26, 2016 at 7:36 PM
    hardground
    Massachusetts
    Beck Arnlej's are $407
    Dorman's are $149
    Anyone know the differences
  3. May 9, 2016 at 2:39 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    NC
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    bump for same info. Replacing my LCA cuz the ball joint is shot and a new LCA is easier to replace than the joint itself (if I do the work myself)
  4. May 10, 2016 at 1:24 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I'm thinking of doing a rebuild of mine, new urethane bushings and moog ball joints. Just need to find a ship to press these bastards in
  5. May 10, 2016 at 1:25 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    I used to order the cheapest ones from RockAuto I could find. I was heavily abusing mine and bent the stock ones and ripped the piece where the bushings and bolt hold it to the truck.
  6. May 10, 2016 at 1:26 AM
    09BlueBeast
    Cody
    Denver
    I'm just afraid to go cheap then go playing and break or bend it
  7. May 10, 2016 at 1:27 AM
    nfs257
    I abuse things a little bit more than most. Browse through my pics lol my rear axle is visibly bent and I have ripped the entire drivers side front out once at 60mph....
  8. May 10, 2016 at 1:34 AM
    09BlueBeast
    Cody
    Denver
  9. May 10, 2016 at 9:35 AM
    nfs257
    They held up ok. I ended up going long travel.
  10. May 11, 2016 at 3:51 AM
    hardground
    Massachusetts
    I just ordered mine for $270 a piece, OEM from partsnet.com
    This is a Toyota dealership, parts department in PA.
    48068-04040
    48069-04040
    Left and right LCA part numbers.
    Found a few places online but this was the cheapest with the $13 shipping.
    That is $210 less than what my dealer was asking for.
    Skootter14 likes this.
  11. May 12, 2016 at 7:47 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    I suggest going with Total Choas top and bottom
    nfs257 and scottalot like this.
  12. May 12, 2016 at 7:56 PM
    hardground
    Massachusetts
    Can't do with my OME kit
  13. May 12, 2016 at 7:58 PM
    hardground
    Massachusetts
    But did look into it and was bummed when I found out TC LCA would not work with OME.
