lower control arms for 1st gen 5 lug
Discussion in '5 Lug' started by showzer, Apr 22, 2011.
  1. Apr 22, 2011 at 11:56 AM
    showzer
    showzer [OP] Well-Known Member
    Shea
    San Diego
    '98 reg cab
    fabtech UCA, Fabtech coil spring, Pro Comp es3000 shocks, flow master exhaust, K&N Intake, throttle body spacer, rhino lined, hella 500 lights, prerunner bumper in the making
    does anyone know if there is someone that makes lower control arms that will fit my truck with a 2.5 inch fabtech lift on it
  2. Apr 22, 2011 at 1:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I don't think I've seen aftermarket LCAs... unless you wanna go long travel
  3. Apr 22, 2011 at 2:00 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    could I go long travel by just getting a LCA and a knuckle? since i already have the UCA
  4. Apr 22, 2011 at 8:00 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    if you have the fabtech uca its not gonna work with LT cuz LT will change uppers lowers and use a uniball on both. coil bucket will need to get cut off and a new one for the 8" travel coilover shocks.
    are you trying to get rid of the weak lbj bracket?
  5. Apr 23, 2011 at 4:36 PM
    MowTaco
    Kansas
    NO
    Going full LT would probably require you to throw at least what your truck is worth back into it again, likely more.
  6. Apr 25, 2011 at 12:55 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    you could look around for a downey setup. im running a downey lower and upper control arm with a downey coilover. all bolt on for my 96 5 lug. they are hard to come by, but work great. its not a "long travel" system. it gives you lift, a smooth ride, and some added travel but, it still uses a ball joint so it will always be limited.
  7. Apr 25, 2011 at 3:25 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    cool where did you find yours?
  8. Apr 25, 2011 at 10:37 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    how much more wheel travel are you looking for?
  9. Apr 27, 2011 at 8:17 AM
    jeffz0rz
    san diego
    you will have to look around everywhere for a downey kit. hard to come by since they dont make em anymore.
  10. Apr 27, 2011 at 9:57 PM
    showzer
    Shea
    San Diego
    '98 reg cab
    as much as possible
