Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Jul 8, 2013 at 12:42 AM
    #1221
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
  2. Jul 8, 2013 at 1:00 AM
    #1222
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    so in reality you will be lowered 2".
  3. Jul 8, 2013 at 1:08 AM
    #1223
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    but the same as a 5 lug. so really not that low
  4. Jul 8, 2013 at 7:53 AM
    #1224
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Didn't you just buy a whole bunch of parts to lift again or are you keeping those to swap them out for the offroad meets?
  5. Jul 8, 2013 at 8:34 AM
    #1225
    Kavik
    Kavik Kavik
    Texas, DFW
    If I could crank a lil bit of power out of this engine. That would be nice.
  6. Jul 8, 2013 at 9:27 AM
    #1226
    Kavik
    Kavik Kavik
    Texas, DFW
    Hopefully I get the supercharger one day to get this truck from 150hp to 250hp but that still seems only better than a couple street vehicles. Makes me sad that there isn't more, I don't think you can even reach 300hp in a 2.7 4 cylinder.
  7. Jul 8, 2013 at 9:42 AM
    #1227
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I just dont get it, seems like a truck that doesn't know wtf it is. but whatever floats your boat.
  8. Jul 8, 2013 at 9:52 AM
    #1228
    Kavik
    Kavik Kavik
    Texas, DFW
    It's all about getting to the 300hp though.
  9. Jul 8, 2013 at 10:02 AM
    #1229
    Kavik
    Kavik Kavik
    Texas, DFW
    Lol Easier said than done, I am not saying it can't be done. It will take a lot of work and tuning.
  10. Jul 8, 2013 at 10:17 AM
    #1230
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What is the stock whp? 130ish? On average, 8.7 psi (turbo) will double the whp from an N/A engine. As long as the setup is efficient and proper. Shouldn't take much more to get it to 300whp on the stock block. I'm actually curious to see if it would be closer to the 8.7 or 14 psi, now.
    200whp on the 1GR. Add 8.7 psi and get 398whp. With a safe tune.
    I know how you can get lower. One of these days, you should swing by and I and you can check out how low mine is. Very simple unless you change transmissions. ;)
    I can show you how to use QA1's up front as well. :cool:
    Because it is morphing into single cab race truck version of mine. o_O
  11. Jul 8, 2013 at 11:22 AM
    #1231
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :cool: you're gonna need bigger guns brah
    woa don't even go there bud. I've been in this game before. I'm not hating on lowered trucks. Just your plan to lower your 4wd. And don't dare go into that whole lawsuit crap either. I'm more for people's rights and more pro choice and anti stupid than you think.
  12. Jul 8, 2013 at 11:32 AM
    #1232
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    8 lbs sounds like fun without anything major that gotta.be changed I wouldn't mind a charger or turbo to make my 4 banger a fun lil truck not much road here on Oahu to fly everywhere but to shut a Honda up once in awhile would.be fun I just like have a lil slider slammed and boosted and slide turns:)
    300whp would be more than enough to pass a stock x
  13. Jul 8, 2013 at 1:02 PM
    #1233
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Probably pass a bolt on only TRD s/c XR as well. :cool:
  14. Jul 8, 2013 at 1:09 PM
    #1234
    Kavik
    Kavik Kavik
    Texas, DFW
    Then lets break down all that is needed to turbo these engines, does anybody know a place to start?
  15. Jul 8, 2013 at 1:21 PM
    #1235
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Singlecabguy already purchased the proper turbo, but for his car.
    GT28, or GT30. If you're a Precision fan, the the similarly sized equivalent.
    A turbo rated for 400hp is the area that you need.
    Then, cut off the flange to the header, and have a tubular welded to the flange. Or buy the flange from Doug Thorley if they make headers for your engine.
    Those are good starting points.
    You could also drop off a header to Alex at PowerFab and he can have a flange made. I am pretty sure that Singlecabguy could do the same through his connections at Hennessey.
  16. Jul 8, 2013 at 1:23 PM
    #1236
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Kase, you or someone else need to take some pictures of the connectors for the factory ECU. That way it will be visible to everyone what they look like, and if a plug n play harness can be made for it.
  17. Jul 8, 2013 at 2:46 PM
    #1237
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just need someone to take a picture of their oem plugs. Unless URD already has a plug n play tuning device ready for the 2.7?
    Once that is figured out, then someone who has purchased an aftermarket header and still has the factory one, needs to get with whoever and send it to PowerFab, to have the flange copied so that a header can be made.
  18. Jul 8, 2013 at 4:04 PM
    #1238
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Noted. Right here right now. ;)
  19. Jul 8, 2013 at 4:08 PM
    #1239
    Kavik
    Kavik Kavik
    Texas, DFW
    Any information that can be brought to the table will make it an easier process, 2 minds are better than one.
  20. Jul 9, 2013 at 8:15 PM
    #1240
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
