lowered vibration
Discussion in 'Street Trucks' started by 10burrito, Jun 12, 2010.
  1. Jun 12, 2010 at 9:24 AM
    10burrito
    10burrito [OP] Member
    Evansville, IN
    2010 BSP Access cab
    3/4 DJM Drop
    Anyone do the DJM 3/4 kit and have a driveline vibration at 65-75 mph or so? Shims on the leafs to fix? Shim the carrier bearing? What'cha got or did ya do to fix it.... it SUCKS. I did not use the pinion angle shims... should I?
    HELP!
  2. Jun 15, 2010 at 4:00 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    usually the driveline vibration is at lower speeds...are u sure its coming from the rear? id check all your bolts make sure their torqued down. you could also check the alignment...that could be the problem
    your running the DJM 4" rear blocks right? they're angled and should correct the pinion angle...
  3. Jun 15, 2010 at 11:46 AM
    10burrito
    Evansville, IN
    2010 BSP Access cab
    3/4 DJM Drop
    Yea, I was wondering if it could be the wheels. I bought em used and only changed 2 tires. The other 2 may be out of balance. (they are on the rear though)
    I'm replacing them soon anyway so I'll see if that helps.
    Thanks,
  4. Jun 16, 2010 at 5:43 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    so the 2 old tires are on the back? yah see if that works, you can always check your ubolts...50 ft-lbs is stock but with blocks you'd wanna torque them down a bit more....
