Lowering back end
Discussion in '1st Gen. Tacomas (1995-2004)' started by 74CO, Apr 2, 2020.
  1. Apr 2, 2020 at 8:05 PM
    74CO
    74CO [OP] Member
    2002 Tacoma Base 2WD Reg. Cab
    Hey, everybody. I've got an '02 5 lug, which hasn't been modded at all, and I'm not really satisfied with the way it sits. I'm a noob to vehicle mods, but I was thinking it'd look 100x better if the back end sat as low as the front. Does anyone know what I need to buy to accomplish this?
  2. Apr 3, 2020 at 6:18 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    5lug? Should be spring under axle. So a "lift block" will lower your truck. You will need to remove the bump stop.
  3. Apr 3, 2020 at 4:52 PM
    74CO
    74CO [OP] Member
    Will this negatively effect the way my truck rides in any way?
  4. Apr 3, 2020 at 5:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    No, unfortunately it will still ride like a broken rollerskate,:eek: only slower and rustier.:rofl::rofl:
  5. Apr 3, 2020 at 5:04 PM
    74CO
    74CO [OP] Member
    Oh, lord. I almost spit my coffee out after reading that one. :rofl:
  6. Apr 7, 2020 at 5:47 AM
    74CO
    74CO [OP] Member
    Does anyone have recommendations for where to procure these materials?
  7. Apr 7, 2020 at 6:48 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
  8. Apr 7, 2020 at 7:01 AM
    74CO
    74CO [OP] Member
  9. Apr 7, 2020 at 8:37 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It sits higher in the back because it's designed to have weight back there. Add weight, it sags.
    So by modifying the suspension to sit level like you describe, you are effectively removing the truck-like capabilities. Removing bump stops IMO is a terrible idea.
    Just put some weight in the bed.
  10. Apr 7, 2020 at 12:35 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    If he lowers the truck, he will be sitting on the bump stops. So he will either have to cut them to be shorter, or remove them.
  11. Apr 7, 2020 at 2:38 PM
    jbrandt
    Justin
    The bumpstops serve a pretty important purpose, and removing them or altering them without careful consideration of how that effects your axle movement is a terrible idea. You also run the risk of bottoming out your shocks which will destroy them.
  12. Apr 7, 2020 at 5:13 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    The shocks stay in the same place. Spring under axles literally just moves the axle with up, and away from the road thus lowering the truck.
    I get you dont like lowering trucks, and it's not really my thing either. I'm just tell the guy what he is going to run into. They make low profile bump stops also.
  13. Apr 7, 2020 at 5:58 PM
    COMAtized99
    North Carolina
    99 DCLB v8
  14. Apr 8, 2020 at 9:31 AM
    jbrandt
    Justin
    I'm talking about removing the bumpstops, not the block lift. When you remove the bumpstops, that will allow the whole axle assembly, shocks and all, to move closer to the body/frame than designed.
  15. Apr 8, 2020 at 1:22 PM
    74CO
    74CO [OP] Member
    Wow, this turned into quite the discussion. Lol.
    My truck is a 2wd, which I mainly use to drive back and forth to work, to the grocery store, etc. I don't haul anything with it or do anything extreme. So I dunno what sorta 'truck like capabilities' I'd be missing out on by lowering it. My main concern is the way the truck looks. I want it to look great, but I also don't want it to drive like crap.
  16. Apr 8, 2020 at 2:33 PM
    jbrandt
    Justin
    That's all well and good, lot of people don't haul a bunch of stuff. I was merely offering a perspective in case you did. I've seen more than one case where some guy lowers (or lifts) a truck only to find out later that it now drives like crap, and he bottoms it out when hauling 2 pieces of plywood.
    Honestly, I would still just throw a couple sandbags in the back, near the tailgate.
    The extra weight does 2 things, makes the rear sag, hopefully leveling it out enough for your tastes.
    But more importantly, it increases traction for your drive wheels. You've more than likely noticed that it's rather difficult to keep the tires from spinning in wet weather. That's because you have essentially zero weight over the drive wheels, meaning zero traction, an our 1st gens don't have traction control.
    People add weight all the time, especially when it snows. This is super useful, even for 4x4s.
    The next best option, would be the lowering blocks, however as I eluded to earlier, I wouldn't chop the bumpstops off without carefully considering the maximum movement of your axle.
