Lowest miles you got from an OEM battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AnchorCop, Aug 7, 2014.
  1. Aug 7, 2014 at 4:36 PM
    AnchorCop
    AnchorCop [OP] Well-Known Member
    Arizona
    13 TRD DCSB 4x4
    Went to change the tacoma battery today. 2013 trd double cab off road, and only 26k miles. Own almost 2 years. Maybe my luck or is the OEM battery this bad? :confused:
    And yes it was covered under warrant 36k/3yrs.:D
  2. Aug 7, 2014 at 4:38 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Mine did just over 3 years, I think my car audio burnt it out
  3. Aug 7, 2014 at 4:41 PM
    la0d0g
    running for the hills
    For crawling not hauling
  4. Aug 7, 2014 at 4:42 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    65k mi and counting on mine.
  5. Aug 7, 2014 at 4:48 PM
    AnchorCop
    Arizona
    13 TRD DCSB 4x4
    Gonna invest in a die hard platinum after this one. Any other suggestions?
  6. Aug 7, 2014 at 4:51 PM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    43K on my 08 still going strong
  7. Aug 7, 2014 at 4:55 PM
    la0d0g
    That
  8. Aug 7, 2014 at 4:55 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    mileage has nothing to do with battery life.
  9. Aug 7, 2014 at 4:57 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    OEM lasted ~ 29 months, less than 20K miles. Second OEM lasted about the same. Have an Autozone battery in there now Duralast Gold. Had one last 9 years in my Camry.
  10. Aug 7, 2014 at 7:09 PM
    AnchorCop
    Arizona
    13 TRD DCSB 4x4
    Good news, the new battery is covered under a new warranty for 2 years worry free.
  11. Aug 8, 2014 at 4:05 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Less then 3 years
  12. Aug 8, 2014 at 9:16 AM
    JPS11
    JPS11 Active Member
    Melbourne, FL
    2011 Prerunner DC TRD OR Black
    26K and right before 3 years. Replaced under warranty.
  13. Aug 8, 2014 at 9:20 AM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    mine lasted 5 years and they said the amps were at 440 instead of 540 or something like that so i went ahead and replaced it.
    really it's kind of cool they test it when you go in for an oil change these days. that way you can replace it before it leaves you stranded somewhere one day unable to crank the truck up.
  14. Aug 8, 2014 at 9:22 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    2009 with 70,000 miles still on the stock one. I have offroad lights and use my bed outlet all the time.
  15. Aug 8, 2014 at 9:24 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Amazing battery. I put one into my Outback when I had it. That thing would crank over in -20 weather just as fast as it would if it was 70 degrees out.
    My Tacoma has the original battery in it with about 62k on it. It seems fine. I've run the stereo + 8" sub for a couple hours up relatively high and it still started the truck without a problem.
    I have the tow package, though, which apparently comes with a beefier battery. I wonder how much better it is than the non-tow package models.
  16. Aug 8, 2014 at 1:14 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Six years, about 70k miles. It was still starting the truck, but tested bad. So I replaced it when I did more as a preventative thing. It was starting to act a bit funny at times and I didn't want it to strand my wife who was pregnant at the time.
  17. Aug 8, 2014 at 2:54 PM
    rickcrna
    rickcrna Well-Known Member
    Rick
    Central Oregon
    '13 AC SR5 4WD I4 Auto MGM
    Am curious if those with batteries that failed early, checked and added distilled water to the chambers as needed to maintain proper volume over the life of the battery.
  18. Aug 8, 2014 at 3:01 PM
    weezer
    southeast
    tacoma 4x4
    probably not. most people don't do that. i was told by someone if you do that and keep the posts clean a battery will last almost twice as long. but who has distilled water sitting around or takes the time to go buy some at the store just for that purpose?
  19. Aug 8, 2014 at 3:03 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Mine went 4 almost 5 years, 50k miles before it went. I noticed you in AZ too, that heat is hard on batteries, not uncommon when I lived there.
  20. Aug 8, 2014 at 4:21 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Distilled water is about $1.50 a gallon at most pharmacies and grocery stores.
