lr uca ball joint moving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mclovin, Mar 29, 2012.
  1. Mar 29, 2012 at 2:42 PM
    mclovin
    mclovin [OP] chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    ok so i've had my lift on for 2.5 mos now and it seems like the upper ball joint is moving inward... i did initial trimming on the fenders and it was good for a long time but recently im rubbing a lot more than what i used to. i know for a fact that they were torqued to the correct foot pounds... anyone have this same thing happen?
  2. Mar 29, 2012 at 4:15 PM
    seric007
    seric007 Well-Known Member
    suspension settling ?
    if your Upper ball joint is moving in and out, its shot.
    test procedure: grab top of tire outside and inside, yank front to back. play? movement? clicking? tapping?
    if the answer is no, its fine.
  3. Mar 29, 2012 at 4:18 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    hes talking about the ball joint bolt to arm connection sliding. maybe it lossened up and slid or you hit something hard with that wheel. I retorqued mine like 5 times after the alignment, they take alot of force.
  4. Mar 29, 2012 at 4:41 PM
    seric007
    thats a tapered fit, it would be making a lot of noise to move like that... i think you'd notice it, well if you ARE concerned pop your wheel off and tighten her back to spec ;)
  5. Mar 29, 2012 at 5:35 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I knocked the shit out of one of my arms and fortunately it just pushed the ball joint all the way in, and didn't bend something.
    Pull it out and re-torque it. I believe they changed the torque specs, might want to pull up the current PDF on SPCs website.
  6. Mar 29, 2012 at 8:17 PM
    kieth
    06 trd
  7. Mar 29, 2012 at 8:37 PM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
  8. Mar 29, 2012 at 8:40 PM
    rcfreak201
    rcfreak201 Well-Known Member
    subd because your username is mclovin :laughing: :laughing: :laughing: :laughing: :laughing:
  9. Mar 29, 2012 at 9:15 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    x2.. Im surprised that it wasnt taken :spy:
  10. Mar 30, 2012 at 5:58 AM
    mclovin
    Biloxi
    you know that would be very interesting, i mean i remember the setting was like 100 something lbs but if its higher.... i guess this weekend i'll have to get in and tighten it back up.
    on another not driving home from work yesterday, had the windows down and i did notice a clicking coming from the front left. sounded spaced out, but more like if you get a rock wedged in your tire... i'll have to listen again today.
  11. Mar 30, 2012 at 6:05 AM
    mclovin
    Biloxi
    i've been lurking for quite some time:spy:
  12. Mar 30, 2012 at 4:27 PM
    mclovin
    Biloxi
    ok so looks like the clicking is gone today so probably not a blown ball joint... going to tare into it this weekend and just tighten the shit out of it... :goingcrazy:
  13. Mar 30, 2012 at 9:21 PM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
  14. Mar 31, 2012 at 9:37 PM
    mclovin
    Biloxi
    well i tore into it today, they most definitely moved...i had them set to +1 instead of +2 so i adjusted that and got it realigned... drives better then the day i took it off the lot. my instructions were at 150, i did 160 this time. just to be sure.
