LR UCA hits springs, what about other brands?
Discussion in 'Suspension' started by Zac808, Mar 26, 2013.
  1. Mar 27, 2013 at 1:25 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Thats weird, mine doesn't touch on either side. 1/4 shim on driver side.
  2. Mar 27, 2013 at 1:29 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Bizarre , even on the hoist with the wheels dangling I'm pretty sure I have lots of clearance
  3. Mar 27, 2013 at 1:33 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Bent spindle?
  4. Mar 27, 2013 at 3:44 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    To much down travel.
    Get some limit straps before you blow them up.
  5. Mar 28, 2013 at 4:02 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Mini H1 Retrofit 5K, 1st Gen TRD CAI, JBA Catback, Radflo 2.5 extended coilovers w/ resis, Radflo 2.5 rear shocks with resis, toytec superflex rear springs, DSM Uniball UCA's, intake manifold spacer
    yeah this is crazy, something is wrong. i have 885's and billy's set at 0 and LR uca's and they come nowhere near my coils at full extension! like someone said up there try messing with your lower arm because it could be loaded.
  6. Mar 28, 2013 at 4:05 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    as a temporary solution (if possible with your setup), rotate the coil 1/2 turn, and it won't hit anymore. that will save your boot while you figure out why you had contact to begin with.
  7. Mar 28, 2013 at 4:06 PM
    XXXX
    sKiP
    05 Prius
    I bet your CV's also hit your LCA shock mount when fully drooped and fully locked :cool:
  8. Mar 28, 2013 at 4:12 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    I've never understood why people do this? when the coil is still going to have the same width and same performance either way its turned?
  9. Mar 28, 2013 at 4:16 PM
    XXXX
    sKiP
    05 Prius
    simple
    in one area is coil
    turn it and it is a gap
  10. Mar 28, 2013 at 4:27 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    look at the back of your coil, it's just like that. same thing either way it's turned. the gap doesn't go away it goes the the unseen side of the coil.
  11. Mar 28, 2013 at 4:29 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    The gap will move up or down depnding on which way you spin the coil
  12. Mar 28, 2013 at 4:37 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    hmm, interesting. didn't know that lol
  13. Mar 28, 2013 at 5:04 PM
    XXXX
    sKiP
    05 Prius
    :D
  14. Mar 29, 2013 at 6:32 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    :popcorn:
    may need 2 bags of popcorn for this thread...
