LR UCA Question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 228Taco, Jul 29, 2010.
  1. Jul 29, 2010 at 7:00 PM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Toytec OME lift without plate spacer up front & with AAL's on back.
    Well its getting towards the end of summer and I finally have saved up some money to spend on my truck :D. I ordered a set of Light Racing UCA's for my tacoma and a few other things. Im excited about getting these...as they seem to be the best bang for the buck. But after doing some research I found that they "had" some issues with the ball joints and bushings. Does anyone know if this has been corrected and/or how to tell when mine arrive that they are ok. Thanks for your help.
  2. Jul 29, 2010 at 7:02 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Last I heard the issue had been corrected...I haven't had any issues with mine :)
    Congrats on your purchases...enjoy :thumbsup:
  3. Jul 29, 2010 at 7:05 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    they were haveing some problems with the ball joint (binding i believe), but that has been completely taken care of. i put a set on over the winter, and they are great. way beefier than the stock arms, and once you are able to describe how to adjust them to the alignment tech (the potentially hard part), they'll get your alignment perfect.
  4. Jul 29, 2010 at 7:05 PM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Thats good news. Just wanted to clarify. Did you install yours? The process seems pretty straight forward but any tips or advice would be welcomed.
  5. Jul 29, 2010 at 7:09 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    install is very easy, jsut don't be afraid to really pull on the inner fender to make room for the long bolt
  6. Jul 29, 2010 at 7:15 PM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Ha alright thanks. Do the instructions do a good job of explaining on how to adjust the caster and camber?
  7. Jul 29, 2010 at 7:23 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you'll have to bring it to get an alignment after you instal them, but in the zero position (the instructions will explain what this is), there are -2 degrees of caster built in to correct for lifting the truck.i just set the camber nut all of the way to the outside to drive to the alignment shop. just a tip...set the camber nut all of the way to the outside and ask the tech to adjust the camber on the truck, not the UCA, that way if the nut ever slips (you hit a curb or really push it off road), you can jsut set the nut all of the way out again and don't have to get it realigned.
  8. Jul 29, 2010 at 7:31 PM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    That sounds like a pretty good idea. Thanks for the advice.
  9. Jul 30, 2010 at 12:31 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Great advice!:thumbsup:
    The binding ball joint, was the issue I discovered and notified Specialty Products about, (That's why I have 3 set of ball joints in my garage:D) back when the LR UCA's first came out and I was doing R&D on my 6" lift to work out the bugs. They found an issue with how the ball joint was being put together. They have since corrected that issue.
    The bushing tearing was because, they were using a rubber that had the wrong durometer. They have since resolved that issue also!
    Their Customer support is Outstanding!! If any issue should arise? They will do everything they can to fix it!
    Great Company to deal with!!
    Congrats on your purchase!
  10. Jul 30, 2010 at 7:29 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Yeah, the problem's been solved for well over a year now. I too have a spare set of bad ball joints in my garage. ;)
  11. Jul 31, 2010 at 1:00 PM
    Brandon###
    Brandon### Well-Known Member
    Install was fairly easy. If I did it over again I would buy a new bolt for the passenger side, and just the the factory one off. Its a pita.
  12. Jul 31, 2010 at 1:03 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    great product
  13. Jul 31, 2010 at 1:07 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  14. Aug 1, 2010 at 9:18 AM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Thanks for all the feed back. Glad to hear they have all the issues worked out now. If I end up cutting the bolt to get it out...would I need to replace it with a special grade bolt?
    Splitbolt thanks for the video that is awesome. Hopefully it will go that easy.
  15. Aug 1, 2010 at 9:22 AM
    Brandon###
    Just get a bolt from the dealer. They're only $12.
  16. Aug 10, 2010 at 11:10 AM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Anybody have a part number for the UCA bolt. I tried to ordered them from my local toyota dealer but the parts guy apparently has killed to many brain cells and ordered the wrong bolts.
  17. Aug 10, 2010 at 11:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    There was nothing to getting the bolt out. IIRC, I bought 2 and used neither since all you have to do is bend the front of the metal of the wheel well an inch or so to get the bolt out. Didn't even break the paint off it. I'll try to locate the bolts after work if anyone reaallly wants to cut theirs off. Seemed like more of a hassle to get the dremmel in a good spot to cut than it was to just bend the metal a bit. No need to move battery or wiper washer bottle either.
  18. Aug 10, 2010 at 11:28 AM
    228Taco
    228Taco [OP] Member
    Pascagoula, Ms
    06 Access Cab
    Yea thats what I am probably gonna end up doing now. Dont feel like waiting on two new bolts to come in.
  19. Aug 21, 2010 at 5:47 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
