LSD ADDITIVE IN NON LSD DIFF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by georgeandkanoa, Dec 31, 2010.
  1. Dec 31, 2010 at 3:00 PM
    georgeandkanoa
    georgeandkanoa [OP] the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    would it be OK to put the additive in my diff if it wan't LSD?
  2. Dec 31, 2010 at 3:26 PM
    JKD
    JKD Well-Known Member
    Waste of money, but it shouldn't hurt anything.
  3. Dec 31, 2010 at 3:26 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Why would you want to? The additive is supposed to help the working of the LSD... no LSD nothing to help. So why put out the extra cash for the additive?
  4. Dec 31, 2010 at 3:39 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    the reason I ask, I painted over the sticker on the differential, and I've read on this form thats how you tell if you have LSD,or is there another
    way?
  5. Dec 31, 2010 at 3:57 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Do you have a TRD Sport or TRD Off Road?
  6. Dec 31, 2010 at 7:28 PM
    JKD
    Lift the rear axle off the ground so both tires can spin. (Obviously you need to chock the front tires well.)
    With the truck in neutral, rotate one wheel. Watch the other wheel. If it rotates in the opposite direction with little resistance, you have an open diff or a worn out LSD. If it rotates the same direction, you have a functioning LSD.
    At least, that's how we always told the difference on older muscle cars.
  7. Dec 31, 2010 at 7:48 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^ With torsen LSD, if there is no preload, I think the opposite wheel will spin the other way even if the diff is in good condition.
  8. Dec 31, 2010 at 11:22 PM
    JKD
    Is the stock Taco LSD torsen or clutch pack?
  9. Dec 31, 2010 at 11:33 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Not to thread jack or anything but I have a lock right posi and I was wondering if I used the additive would it be any different
  10. Jan 1, 2011 at 7:00 AM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    TRD Sport
  11. Jan 1, 2011 at 7:23 AM
    KenLyns
    Belly of the Beast
    It is most likely torsen. The older 4Runner and pickups used torsen rear diffs. Today's full-time 4WD Toyotas (4Runner Limited, GX460, LX570) still use torsen center diffs.
    Anyway, TRD Sport models should come with the LSD standard.
  12. Jan 1, 2011 at 7:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No. THe TRD LS Diff uses friction plates, and needs the addative. The Torsen LS was used in the Toyota Supra, And SC430 in the rear, and the AWD 4Runners, Landcruisers, and some AWD Fj's used them in the center.
  13. Jan 1, 2011 at 7:38 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    then yes, you have the mechanical LSD in your 07 sport
  14. Jan 1, 2011 at 9:29 AM
    KenLyns
    Belly of the Beast
    Thanks. Learn something new everyday...
  15. Jan 1, 2011 at 3:14 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    thanks guys,i'll add the additive when I change it
