LSD fluid in Non-LSD
Discussion in 'Technical Chat' started by 747, Jun 3, 2010.
  1. Jun 3, 2010 at 6:10 PM
    747 [OP] function > form
    1st Gen.
    Just changed diff. fluid, and used Hypoid gear oil API GL-5 "plus" 80w-90, the "plus" indicates limited slip suitability (as per the jug). I don't have a LSD (that I'm aware of...pretty sure it's open with a locker -- 03 TRD Off-Road Pre).
    Anyway...what will (or could) happen as a consequence of using the aforementioned LSD suitable fluid?
    Fluid brand: Sta-Lube.
  2. Jun 3, 2010 at 6:15 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
  3. Jun 3, 2010 at 6:27 PM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    McKinleyville, CA
    2015 Black Tacoma AC TRD 6MT V6
    Yep should be ok :) its bad if the other way around, if you use non lsd oil in a lsd rear-end. Most lsd oil is just regular gear oil has additives that allow the clutch packs function correctly in the LSD. You can even buy lsd oil additive for regular oil. As long as you have the right weight oil in there you should be good to go :)
  4. Jun 3, 2010 at 6:29 PM
    1st Gen.
    Whew...btw, here's where I found the recommended weight/type for my taco: (see page 4 of 4). Thanks guys.
