LSD in 2006 2wd i4 manual
Discussion in '4 Cylinder' started by jakara059, May 26, 2010.
  1. May 26, 2010 at 2:11 PM
    jakara059
    jakara059 [OP] Member
    JB
    Missouri
    2WD I4 Manual
    I've noticed that 2010 models come with LSDs. Can I get such a thing for a base model 2006 Tacoma? I mostly highway communte, but I live in the country and have a several hundred yard hilly driveway that I cannot use the Tacoma on in inclimate weather. I also may want to have confidence on boat ramps, or when driving across muddy land, etc. Would the LSD be good for this? I don't really want a 4x4 because I need the highway mileage (I get slightly over 25 average.)
    If this aftermarket part is available...will it screw with my on-road performance?
    Thanks!
  2. May 26, 2010 at 2:27 PM
    Barnone
    Barnone Guest
    jakara059,
    I can't help you with the swap but I also have a long rough steep driveway here in WNC so am interested in trying or hearing about how the 2010 LSD does. My 2002 auto does ok but I would be more comfortable with both rear wheels driving. I am considering a 2010 but I don't want to give up the regular cab auto.
  3. May 26, 2010 at 8:56 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Here's what I've learned from my research on the subject. There are a few aftermarket options for traction aiding devices. Your options are:
    • clutch type mechanical LSD like an Eaton posi
    • torsion type mechanical LSD like an Eaton/Detroit Truetrack
    • automatic locker like a richmond gear powertrax no-slip or lock-right
    • selectable locker like an ARB air locker
    Clutch type LSD's are probably more useful for street driving. They can be finicky with gear oil (Eaton recommends dino oil) and require additional additive to the oil.
    Torsion type LSD's are also probably more useful for street driving too. They do not require additive, but Eaton recommends dino oil in their truetracks.
    Automatic lockers (lunchbox lockers) are probably more suited for dedicated off road rigs, but are also popular with daily drivers. They can be noisy when they engage/disengage but typically don't have specific oil requirements. Probably the cheapest to install, but not very street friendly.
    The ARB is probably the most robust and most favored for it's offroad capabilities. It is air activated and requires an on-board air compressor to activate/deactivate it. It is probably the most expensive option as well. It only works when you want it to.
    I'm sure plenty of people will disagree with me, but the above seems to be the general consensus, at least for a 2wd truck
  4. May 27, 2010 at 12:49 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    If you have the 6 lug, yes, you can install a LSD. The 5 lugger, I do not believe has any aftermarket support for a LSD.
  5. May 27, 2010 at 4:38 AM
    afd23a
    The Dynamo of Dixie
    That's a good point. I forgot about that. At least Eaton's devices (at least the truetrack, so I assume the others as well) require the rear end gear ratio to be between 3.54-5.29. On a manual 5 lug taco, the above devices wouldn't fit without changing the gear ratio which can be costly.
  6. May 31, 2010 at 9:33 AM
    jakara059
    JB
    Missouri
    2WD I4 Manual
    Oh...bummer. I was REALLY hoping to have a limited slip option. In perusing the site to now, I haven't seen it mentioned that the 5Lug base models couldn't be upgraded with an aftermarket LSD. Does anyone know if there MIGHT be an option out there? :(
  7. May 31, 2010 at 1:37 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I wouldnt mind LSD
  8. May 31, 2010 at 4:36 PM
    Barnone
    Barnone Guest
    Would the 2010 LSD work in the 2006? Could you just swap out the whole rear end?
  9. May 31, 2010 at 8:55 PM
    afd23a
    The Dynamo of Dixie
    2010's have the auto LSD which is really just electronic controlled braking. Probably hard to swap in.
  10. Jun 1, 2010 at 5:49 AM
    Barnone
    Barnone Guest
    Thanks for the education.
    So there is not a practical way to install a LSD in a five lugger (first or second gen)?
  11. Jun 1, 2010 at 6:24 AM
    afd23a
    The Dynamo of Dixie
    I guess not...at least in a 2nd gen. Not sure about first gens. A powertrax is still an option but I'd research it or take a ride with someone who has one so you know if it's something you want.
  12. Jun 1, 2010 at 12:38 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I thought someone who re-did their gear ratio with a V6 ratio used the 3rd member from the 6-lug on the 5 lug truck. Maybe this would allow you to use a after market limited slip? Not sure....
  13. Jun 1, 2010 at 1:12 PM
    jakara059
    JB
    Missouri
    2WD I4 Manual
    What about an ARB selectable? Will this work on a 5lugger?
  14. Jun 1, 2010 at 6:19 PM
    afd23a
    The Dynamo of Dixie
    You can use a third from a 6 lug, but that means a gear ratio change, additional cost for the third member, and then adding an LSD if it doesn't already have one. I didn't think the op wanted to change gear ratios.
  15. Jun 2, 2010 at 7:19 PM
    SC4333
    Grant
    FL
    To sum it up, no you cannot put an LSD in the 5 lugger, base model tacos. You can put a LSD carrier in all of the 6 luggers, except for the TRD off road models that untilize the 8" rear end.
    The five lugger axle housing will not accept the "8.4" third member, gear change or not.
  16. Jun 3, 2010 at 7:50 AM
    afd23a
    The Dynamo of Dixie
    not sure about that one, I never investigated it.
  17. Jun 9, 2010 at 5:47 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Your truck has "Auto-LSD". Toyota's brake system based traction system that limits wheel speed differences similar to a Mechanical LSD.
  18. Jun 30, 2010 at 4:03 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I saw someone that had a truck identical to mine (a first gen 5 lugger with the 2.4) who put an aussie locker in his rear end. He said the manufacturer says it wont fit but it bolted right in.
  19. Jun 30, 2010 at 4:26 PM
    numbah57
    kahai
    Maui, Hawaii
    I meant a real one, not that braking bull shit
  20. Jul 2, 2010 at 9:44 AM
    MikeTaco
    MikeTaco Let's do this!!
    Miami, FL
    07 Regular Cab
    A Few...
    I have a base model regular cab. I was able to put Powertrax Lockright in mine without changing the gears.
