LSD in a 2015 4cyl?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krautesupreme, Feb 3, 2018.
  1. Feb 3, 2018 at 3:55 PM
    Krautesupreme
    Krautesupreme [OP] Member
    2015 Tacoma
    hey guys. May be a dumb question - first time on the forum. Just wanted to know if my 2015 access cab - 4wd - 4cyl has a LSD. I’m replacing the diff oil this weekend and just wanted to be sure before I crack it open.
    Thanks!
  2. Feb 3, 2018 at 3:59 PM
    Bishop84
    Bishop84 Well-Known Member
    No, standard GL5 oil for your truck. LSD hasnt been used in our trucks since 2008.
  3. Feb 3, 2018 at 4:08 PM
    Krautesupreme
    2015 Tacoma
  4. Feb 3, 2018 at 4:40 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Yeah will be just fine with Mobil 1 75w90, that's what I'm using in mine
  5. Feb 3, 2018 at 6:48 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    The limited slip is computer controlled and not in the diff. You'll be fine.
  6. Feb 3, 2018 at 7:34 PM
    Pigpen
    Dan
    Northwest Montana
    The additive is fine in a non-lsd diff. I run it most fluid changes, as that's what's most readily available.
  7. Feb 4, 2018 at 11:19 AM
    Krautesupreme
    2015 Tacoma
    Thanks for the help!
