LSD Problem, maybe. Someone Diagnose what's going on!
Discussion in 'Technical Chat' started by 28ØØ3, May 5, 2010.
  1. May 5, 2010 at 6:55 AM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    I need help diagnosing a problem, if indeed it is a problem. I'll try to be brief in explaining the issue.
    Setup: A few weeks ago I changed my Front Diff, TC, and Rear Diff fluids. I used Valvoline Dino 75w-90 (link). My Rear Diff has the Mechanical LSD, so I used the Trans-X LSD additive (link). In the Rear Diff, I used 3qts of oil + 7oz LSD additive.
    Problem: Whenever I make a sharp left turn (usually from a stop), I get a low frequency "whump, whump, whump" sound. I haven't noticed it on right turns or "non-sharp" left turns. Anyone ever had this happen to them before? Is this a problem? or am I just paranoid? Should I just drain the diff and replace with the Toyota 'stealership' additive?
    Any and all advice would be helpful. Thanks.
  2. May 5, 2010 at 7:00 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Where's Chris when we need him?
    :notsure:
  3. May 5, 2010 at 7:01 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    i've been discussing this with him. he is baffled as well
  4. May 5, 2010 at 7:05 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
  5. May 5, 2010 at 7:06 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Maybe too much LSD additive. I put a 3.5 OZ tube in mine and i couldnt get a full 3 quarts of gear oil in.
  6. May 5, 2010 at 7:10 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Subscribed. I have some Redline 75-90 GL5 gear oil and some Redline LSD additive that I still need to swap out on my truck. Weathers warming up finally so hopefully I can get to it soon.:eek:
  7. May 5, 2010 at 7:22 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i don't know if it's the same, but when i redid mine, it "stiffened" up the LSD. at lower speeds, when turning, i got that low frequency sound you mentioned, and a very minor vibration. almost felt similar to the carrier bearing vibe when you lift the rear. it made it act almost like a locking diff when i turne on gravel, dirt, or something else slick. I don't mind, as it's been over 15,000 miles since then with no problems, and it seems lo have given me slightly better traction off pavement. if it's just the sound you're getting, i'd say it's probably just the oil/diff additive combination you used, but if it doesn't bother you too much, i think the diff will be just fine. if it does bother you, oil isn't that expensive.
    sorry, i know i didn't solve your problem, jsut wanted to let you know i have a similar case with no problems
    btw, i'm running synthetic, so that contributes to it a little too.
  8. May 5, 2010 at 7:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Drive in tight *8* circles in both directions - that's supposed to get the friction modifiers into the clutch paks. Do it several times in both directions.
    If this doesn't help and the LSD still seems grabby, then you might need MORE friction modifier.
  9. May 5, 2010 at 7:52 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Use dino 80w-90 w/ LSD additive.
  10. May 5, 2010 at 7:59 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    i will try this in the afternoon
  11. May 5, 2010 at 10:24 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I didnt know this.:rolleyes: Thanks for the info!!:D
  12. May 5, 2010 at 10:54 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Mine does the exact same thing -- seems to be worse on a left turn. However aside from when I first put it and befor the mixture had a chance to mix I never noticed it before.
    I am with the post above -- more modifier might be the fix. Let s know how it goes
  13. May 5, 2010 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Subbed. Still puzzeled by this. I tried to duplicate the issue with my truck, to no avail.
  14. May 5, 2010 at 6:03 PM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    updates:
    1. i couldn't find a place with a big enough parking lot (and empty enough) to do the figure 8's, but i did powerbrake and laid even tread from both tires
    2. my diff drain plug had some oil on it (just a few drops), but there was no oil where i normally park, so i wiped it with a rag and we'll see if it is wet later
    3. i did, however, make some really tight turns and after that, while making turns, i didn't notice the "whump" sound.
    4. also, when i made the tight turns, no chatter, no wheel hop, and didn't feel like it was binding
  15. May 5, 2010 at 6:19 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I have noticed this too in mine, but it only seems to be when I first start driving. That or I just don't happen to notice it later in my trip. Although I'm sure I need to change my fluid, just haven't gotten around to it.
    TRD mechanical LSD, original fluid, rear end hasn't been touched since I got it new.
  16. May 6, 2010 at 6:09 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    I have been reading several forums (ttora, toyotanation, etc) and it seems alot of people are having problems with noise in the LSD after they changed the rear diff oil
  17. May 6, 2010 at 6:55 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Hey look, It's me. I just had to chime in on this one. I took it in for the rearend noise as the work order states. Next thing I know, their solution was a Rear Spring TSB....:confused: The noise came back after about 500 miles. Maybe the tech took it out back and did a few "8's" with it to quiet everything down. The springs look good though. I will follow up on this because of the interest that others are having the same problem. The other thing that concerns me is that I took off the "fill" plug to make sure the fluid was Okee Dokke and it released pressure similar to someone opening a beer can slowly. I just cracked the plug and a boatload of SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS........came out. I know another member had mentioned that his housing sounded pressurized too. I had 15,000 miles at the time. All pavement driving so I'm not sure if the breather is/was clogged and how it could get clogged going to the Piggly Wiggly and back.
  18. May 6, 2010 at 7:09 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^ that sounds like the breather is clogged or something.
  19. May 6, 2010 at 7:48 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    lol, rear diff is making noise.....change the rear springs! makes perfect sense
  20. May 6, 2010 at 7:59 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
