LSD rear diff oil additive question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Jan 4, 2010 at 4:35 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I've already searched and gone through thread after thread not quite finding what I'm looking for.
    I want to change the rear diff fluid in my '07 mechanical LSD. I already read that the safe route was 80W-90 conventional oil and a tube of LSD additive. So today I picked up 3 qts of Valvoline 80W-90 gear oil and a tube of Trans-X Posi-Trac additive.
    Two questions:
    1. Is this a good additive? Or is there something better I should look in to?
    2. This tube is 7oz. I've seen other tubes are 4oz. Is 7oz too much to add? Or should I just stick the whole thing in there? The tube says to "add entire contents of tube to differential", but then says "do not overtreat". :confused:
  2. Jan 4, 2010 at 4:39 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I would just use the entire tube. Remember add the contents of tube after the first quart of oil, you don't want to fill with oil and can't add the additive.
  3. Mar 10, 2010 at 7:05 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I used as close to half the bottle as I could and it worked fine for me.
  4. Mar 10, 2010 at 8:13 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Never used that brand, but what I can tell you is I have used this combination with no problems at all...
    Go to Ford dealer and purchase 3 bottles of the SAE 80W-90 Premium Rear Axle Lubricant
    http://fcsdchemicalsandlubricants.c... Rear Axle Lubricant&category=Transaxle Fluid
    Then also purchase the 4 oz. bottle of the Ford LSD Friction Modifier
    Add the entire bottle of friction modifier to the rear first then fill with the rear axle gear oil
    Mine took close to 3 quarts after I put the friction modifier in
    You want the level just under the fill hole
    Then drive around for 10 minutes and do a bunch of figure 8's in a parking lot
    Come back back home on level ground and check the level again making sure it's just under the fill hole
    Take the spare tire out it's so much easier
  5. Mar 10, 2010 at 8:51 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    I also bought my friction modifier from Ford, but it was made by Motorcraft or something like that. That with Valvoline 80w-90 havent had any issues yet. Then again, it's only been about 3K miles.
    Check with your local Toyota dealer. My local one sells Kendall LSD oil for only $5 qt.
    1st time I've heard someone recommend removing the spare. Shouldnt be an issue unless you're tugging around your own "spare tire"......:p
  6. Mar 11, 2010 at 4:02 AM
    PA452
    Western PA
    I also dropped the spare when I did my rear diff. If you're not using a pump, it makes it much, much easier to get the bottle at an angle where you an pour.
  7. Mar 11, 2010 at 3:44 PM
    WATacoRider
    TRD Sport 4x4
    Well that's true. I just assumed everyone would be using a pump.
  8. Mar 11, 2010 at 4:10 PM
    PA452
    Western PA
    I should have. Although I had to use the 3 quarts and the 8oz of LSD additive, and the oil level was still just barely up to the fill hole. Not sure that the pump I later bought when I did my transmission and transfer case would have pulled out what I needed from those bottles. I may have needed to do some pouring anyway.
