LSD vs Auto LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rcastle57, Oct 26, 2010.
  1. Aug 31, 2012 at 1:04 PM
    #41
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
  2. Aug 31, 2012 at 2:35 PM
    #42
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    Naaa the Toyotas are great!!! Only vehicle type that stands up to the abuse!!
  3. Oct 27, 2012 at 9:28 AM
    #43
    mtcarrio
    mtcarrio Active Member
    New Orleans
    2007 TRD Sport
    Skid plate, debadged
    Hey do you know the break down for a 2007 4WD Sport?
    I have the mechanical LSD and A-TRAC, i dont know??
  4. Dec 24, 2013 at 7:32 PM
    #44
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    We have a 2011 truck with both Auto and mechanical LSD installed as the Auto LSD eats rear brakes in less than a month.
  5. Dec 24, 2013 at 8:32 PM
    #45
    Luis1
    Luis1 Active Member
    Alberta, CA
    2013 Tacoma DCLB TRD SPORT 4x4
    - 20" or 30" LED light to go into the lower grill - Hell Bent Steel 2.5" leveling kit - Goodyear Wrangler Duratracs 265/70/17 on stock aluminum rims
    ok so I have a 13 sport 4x4. in 4hi is the engine retarder on with trac on and then is turned off when the vsc button is pushed or is it off automatically when i put it into 4 hi. I know the '12's have this design, but what about the 13's?
  6. Dec 25, 2013 at 5:07 AM
    #46
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I had a mechanical LSD on my Dakota. The Toyota brake system is much better than mechanical. With mechanical both wheels must have traction in order for it to work. With Auto LSD the wheel with traction will get you moving even if the other wheel is spinning.
    Stick with what you have.
  7. Dec 25, 2013 at 5:10 AM
    #47
    Jimsc
    Jim
    Greenville, SC
    What??? You can't be serious. Toyota would never design a system that would do that.
  8. Dec 25, 2013 at 6:35 AM
    #48
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Mech. LSD is a proactive traction control system. It provides power to both rear wheels before you lose traction. Auto. LSD is a reactive traction control system. It only operates after you lose traction, until then you only have one wheel drive. If I had a choice I would take the MLSD any day.
  9. Dec 25, 2013 at 1:30 PM
    #49
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You are half correct. Your Dakota had Truetrac, which indeed does have a problem when one wheel completely loses traction. However, Toyota used Hino LSD which works more like lock right, except it does not fully lock axle. Apples and Oranges.
  10. Dec 26, 2013 at 7:20 AM
    #50
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Yes I am correct..the sandy mud Eats rear brakes in less than a month. I am talking about Guyana South America..extreme conditions. When the brakes are wet and worn out...no AuTO LSD!!!!
