LSK race long travel.
Discussion in 'Long Travel Suspension' started by lemons6245, Jan 30, 2020.
  1. Mar 18, 2022 at 6:00 PM
    #61
    lemons6245
    lemons6245 [OP] Well-Known Member
    2012 Tacoma Prerunner 4x2
    LSK race long travel, King 2.5x10 coilovers, 2.5x10 bypasses and 2.0 bumps. 2.5 Tundra fox rear DSC shocks, Icon RXT pack, Icon bump stops. 4.88 w/ TruTrac. AFE Y Pipe, URD cat-back. CSF radiator, OVT 91 tune, Ripp coil packs.
    The only issue I had was LSK give you these rectangular tabs for the lower control arms that mount to the frame of the truck where the camber bolts would be. I had the TC cam gussets and unless you weld those rectangular tabs down every time you make a turn at lower speed if will sound like the whole truck is going to snap because the tabs hit the gussets.
  2. Mar 21, 2022 at 12:31 PM
    #62
    dirtytacoma
    dirtytacoma Well-Known Member
    Cody
    Utah/ San Diego
    4th YOTA 05 DCSB
    Sounds good, ill have to look into that when the time comes. Other than that youve been pretty happy with the kit overall? Performance, durability and what not?
  3. Mar 21, 2022 at 5:18 PM
    #63
    lemons6245
    Overall I am stoked on the kit. I originally had 2.5 bypassed, but since have gone to a 3.0 because that is what the kit was designed around. It does help as with any LT or mid travel set up to have the coils and bypasses tuned properly to get the full advantage of the kit. Other then the clunking which was sorted out I love it. The only things I would do at the same time if you are putting the race kit on are the lower control arm gussets either from marlin crawler or jd fab, the engine support brace that connects both shock towers (along with the extra support for the shock towers as you can see on the op). The only thing I had to constantly check was the steering celvis. My passenger side one would rotate slightly every now and them. Not enough to do any damage, but if I never checked it it probably would have. Now with the JD fab slide rack I don't have to worry about that, but that really was the only downside to anything, but nothing that LSK designed has been an issue.
    dirtytacoma[QUOTED] likes this.
  4. Jul 20, 2022 at 12:58 AM
    #64
    dirtytacoma
    Cody
    Utah/ San Diego
    4th YOTA 05 DCSB
    The more I research the kit the more I want to hurry up and pull the trigger on it. You've helped me address some concerns, one more thing came to mind. If the lowers become fixed with no cam bolts and those weld on plates, im assuming alignments are handled with the heims in the upper arm to control camber and maybe some caster?
  5. Jul 21, 2022 at 7:59 PM
    #65
    lemons6245
    Correct that is corrected with the Heinz on the upper control arms. The real only downside I have with that is that to adjust I have to remove the upper control arm (not all the way only the bolts holding it to the support on the frame) adjust and the recheck.
  6. Jul 22, 2022 at 3:41 PM
    #66
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I prefer mustard on the upper control arms.
  7. Jul 22, 2022 at 4:06 PM
    #67
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    RonRon23[QUOTED] likes this.
  8. Jul 22, 2022 at 4:41 PM
    #68
    lemons6245
    Hahahha
    autocorrect
    Airdog[QUOTED] likes this.
  9. Nov 14, 2022 at 6:37 AM
    #69
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm impressed. The camber stays near zero the full range it looks like.
    I stared at an earlier image for a while trying to figure out why my brain thought something was amiss, then realized this is a prerunner. My brain was like "where the CVs at doe?"
    Awesome build! :thumbsup:
  10. Jan 4, 2023 at 3:58 PM
    #70
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    What are the two spring rates and lengths you are running on that coil over ?
