LT 4X4 Axles
Discussion in 'Long Travel Suspension' started by TacomaDan, Oct 8, 2010.
  1. Oct 8, 2010 at 8:03 PM
    TacomaDan
    TacomaDan [OP] Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    So I heard from a bird that you can use Tundra 1st gen Axles on a 1st gen Taco to work with LT. Is this true???
  2. Oct 8, 2010 at 8:22 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Yup it's true. I'm running them. But the cv joint themselves are different.
  3. Oct 8, 2010 at 8:42 PM
    TacomaDan
    Daniel
    Woodland, CA
    Arent they real CV joints? not the crappy tripod joints on tacomas?
  4. Oct 8, 2010 at 8:45 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    I dont know about the cv joints but the tundra axles will only work on a kit that is 3.5" over per side. so TC and Camburg are the only 2 kits I know of. Engage is 4" over and been working on trying to get axles to work for a LONG time.
  5. Oct 8, 2010 at 8:48 PM
    TacomaDan
    Daniel
    Woodland, CA
    Ya I'm going Camburg some day. Just arming myself with knowledge. I'm not holding my breath for Engage either...
  6. Oct 8, 2010 at 8:52 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    A tundra joint will not fit on a taco. I asked around last month.
    And that is true about tc and camburg.
  7. Oct 8, 2010 at 8:54 PM
    TacomaDan
    Daniel
    Woodland, CA
    ? Like are you saying you tried to fit a tundra joint into a tacoma stub axle? ya it wouldnt work. The tundra has a 6 ball CV joint where as the tacoma has a "tri" pod joint.
  8. Oct 14, 2010 at 7:25 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You need the axle from a Tundra and the joint off your Tacoma. It's a giant PITA to put them together, from what I've heard.
  9. Oct 14, 2010 at 12:14 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    It is. Thats why TC sells their 4130 built half shafts for so much.
  10. Sep 10, 2019 at 4:29 AM
    upongame619
    upongame619 Well-Known Member
    Danny
    98 Taco
    Home built Mid Travel Front and rear, need help new to this
    Yes, The tundra axle will work, Yes it has a better design from what i've been told. To achieve the full amount of travel you will need to trim it slightly ( I do not want explain in case i use the wrong name for things ). I purchased my tundra axles with trim with longer boots from CVJ axles and have had 0 issues thus far, cycled suspension travel with no bind on Solo Motorsports LT kit is 14" with .5" diff drop
  11. Sep 11, 2019 at 1:33 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This thread has been obsolete in the 9 years no one posted on it...
