LT install help!
Discussion in 'Long Travel Suspension' started by Lil'Taco, Sep 6, 2012.
  1. Sep 6, 2012 at 7:07 PM
    Lil'Taco
    Lil'Taco [OP] Well-Known Member
    Scotty
    Corvallis, OR
    2010 PreRunner Sport DCSB
    Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights, aFe CAI, Borla Cat-back exhaust, Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts.... It has more stuff done to it now.
    So I'm in the middle of installing my Total Chaos +2 lt kit and I come to the UCA and it shows that I need to install 4 of these washers that came with the kit but the problem is the gap between the inside of the UCA and the Coil bucket isn't wide enough to install a second washer on the inside.
    Any help would be nice ASAP. I'll post a picture in a second.
  2. Sep 6, 2012 at 7:10 PM
    Lil'Taco
    Scotty
    Corvallis, OR
  3. Sep 6, 2012 at 7:14 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    GL OP Bump! hopefully someone more keen on installs chimes in.
  4. Sep 6, 2012 at 7:15 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    It WILL fit. I had the same issue with my Burg LT. I gently tapped the other washer in with a hammer, worked like a charm.
  5. Sep 6, 2012 at 7:18 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    I would call TC but they closed 30 minutes before I called and they are closed Friday-Sunday!!! bump
  6. Sep 6, 2012 at 7:19 PM
    08pretaco
    Oliver
    az
    Dude it will fit. Take your time and go back to it and try. Worst case scenerio, I do not recommend, is making the shim thinner if you have a grinder at home.
  7. Sep 6, 2012 at 7:19 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Does you kit utilize stock shocks?
  8. Sep 6, 2012 at 7:19 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    The most gap I can get is only half the size of the provided washer though, I don't fell like I should have to grind one of the sides down to make enough room, but thats the only option I can really see...
  9. Sep 6, 2012 at 7:20 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    No some new 8" fox shocks are going in but wanted to get everything started.
  10. Sep 6, 2012 at 7:21 PM
    08pretaco
    Oliver
    az
    Try tapping it in. I thought also it wouldnt fit but somehow it did.
    Have the washer at an angle towards the bushing, then gently try to tap it in.
  11. Sep 6, 2012 at 7:23 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Don't do that. If you make it thinner it will eventually flareout, distort, or even break. Like others have said, take your time.
  12. Sep 6, 2012 at 7:24 PM
    08pretaco
    Oliver
    az
    Hence the absolute reason I am stressing to him to take him time and get it to work the way it is. "I do not recommend"
  13. Sep 6, 2012 at 7:28 PM
    Haslefre
    Haslefre Not Really Here
    Brady
    Puget Sound
    09 Offroad 4x4.
    IronMan4x4 Foam Cell Pro Fronts, IronMan 2" rear leaf pack. Relentless 1/4" steel skid plate. Weathertech Digital fit front floor liners. BAMF Sliders with kickout. HomerTaco Satoshi grill.
    Hey bud, if we end up staying the night back there Saturday ill come by and help you. No promises though since we might just turn Saturday and go home
  14. Sep 6, 2012 at 7:31 PM
    MonkeyProof
    SoCal- SGV
    :thumbsup:
  15. Sep 6, 2012 at 7:31 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    Oh I'll be working on this all weekend. I have help coming tomorrow (when I had originally planned to start) but need to get the spindles off today to get welded tomorrow morning.
    Your more then welcome to come by and help when ever you want, I'll be on this all night.
  16. Sep 6, 2012 at 7:38 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    there is just no way to even wedge the washer in there before it goes on. I'm stumped!
  17. Sep 6, 2012 at 7:41 PM
    Haslefre
    Brady
    Puget Sound
    09 Offroad 4x4.
    Yeah there is. Take the largest flat head screw driver you have and pry it open. Will take a bit of work but you can do it.
  18. Sep 6, 2012 at 7:41 PM
    08pretaco
    Oliver
    az
    Maybe try putting the front washer in first then try the back.
  19. Sep 6, 2012 at 7:42 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    Alright here's an idea. Take off the Rubber red pieces, pulling a blank on what they're called haha, and throw them in the freezer along with the washers. When they get cold they'll shrink, I dont know how much hah but it might just give you enough room to squeeze the washer in.
    Just an idea though
  20. Sep 6, 2012 at 7:49 PM
    trdNick
    trdNick Odie
    Texas
    07 Trd Off Road AC PreRunner Grocery Getter
    bushings haha
