LT recommendation for keeping tire stickout ~flush with 4" Fiberglass?
Discussion in 'Long Travel Suspension' started by jwarr, May 4, 2021.
  1. May 4, 2021 at 2:14 PM
    jwarr
    jwarr [OP] Well-Known Member
    So I have just started researching and I’m sure all of this has been asked and answered before, but I do have some specific things that I am trying to target if you guys have a minute for an opinion.
    I have a 2008 access cab 4x4 manual transmission and would like to improve the look and suspension. I like +4" fiberglass front and rear and don't really want to go anymore than that on the body and would like to keep the tire stick out to flush or maybe 1” or less out.
    I am thinking a +2" kit with 17x8.5" wheels (0 offset, 4.75" BS)with a 315/70-17 tire. then running a 1.5" spacer in the rear on the stock axle?
    Thoughts?
  2. May 4, 2021 at 10:05 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. May 5, 2021 at 4:20 AM
    jwarr
    Thanks! Some I like, some are sticking out too much for me and my State inspectors. It is hard to extract specifics from just pictures. Anyone have a recommended path to get close to what I am looking for as a starting point?
  4. May 5, 2021 at 6:14 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’d consider the McNeil +2 glass
  5. May 5, 2021 at 5:11 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I have 4" ADV fiberglass, a 3.5" lt kit, spindles that are another 3/4" (2wd), and 285" tires on wheels with 0 offset / 4.75" backspace.
    Depending on your tire size and wheel combo, a 3.5" kit fills 4" glass perfectly.
    04TacoRunner likes this.
  6. May 6, 2021 at 4:09 AM
    jwarr
    Thanks! Do you have any pics right down the side to show how well the tires are covered? What to you mean by "spindles that are another 3/4" (2wd)"? And lastly, what do you have in the rear to widen the rear track? Wheel spacers?
  7. May 6, 2021 at 7:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Aftermarket 2wd spindles can push the wheel mounting surface out wider since there’s no cv to require the stock width.
    Only wheel spacers or a new axle or full float conversion which I don’t think 2nd / 3rd gens have can have widen the rear.
    Sterling_vH111 likes this.
  8. May 6, 2021 at 7:49 AM
    Sterling_vH111
    Sterling
    socal
    This is what I meant:
    And yes I have a few more photos.
    121B5DCF-B6D8-47E3-A2F9-0D4F28D6A684.jpg 5BC9CA82-C226-4B8C-9722-C39392088BEE.jpg298D7DBC-D6F9-48A7-A362-DBA396E4EA57.jpg
    In the rear i have nothing at the moment. But will put probably 2” wheel spacers on when I get actual 35”s this year.
    Don’t really have any pics of the rear width.
    Epic3rdgen and Dalandser[QUOTED] like this.
