LT Suspension vs. A Regular Lifted Suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobby632, Apr 3, 2013.
  1. Apr 3, 2013 at 8:55 PM
    bobby632
    bobby632 [OP] Active Member
    Bobby
    Tucson
    I am about to my buy my first Taco! :) I have seen the LT suspensions and it looks like shocks get set up in the bed and then wider front and rear fenders. What is the point of an LT suspension? What type of off-roading is it built for? And finally why do people do the LT suspension versus the regular lifted suspension?
  2. Apr 3, 2013 at 8:58 PM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Good question for one money, Pro Comp (me) versus Kings/Icon (LT) let's just say i'd be turning around to go home with a broken truck long before them if they ever did ahaa
    That's my input now :popcorn::popcorn:
  3. Apr 3, 2013 at 8:58 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    in short
    "lift"=
    raising suspension with stiffer coils/leaf packs, paired with longer shocks. stock length arms and stock/stockish shock/spring hangars
    LT=
    complete suspension swap, longer arms, longer leaf packs, longer shocks, gusseted everything, longer everything.
    mainly used for high-speed stuff. longer, stronger shocks and longer arms means more, controlled travel.
    lift-go slow over shit
    LT-fly over shit
    theres a metric fuckton of info on this stuff around the forum, try taking a look at it.
  4. Apr 3, 2013 at 9:09 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  5. Apr 3, 2013 at 9:39 PM
    bobby632
    Bobby
    Tucson
    :thumbsup:
    Couldn't have explained it any better man, thanks! That's exactly what I like to do is "fly over shit" !:kona:
    So my next question would be then I have only seen the LT suspension on single and ext cabs. I'm wanting to get a double cab, can I steel do the LT suspension. Does the LT limit what kind of trails I can go on because they are obviously not as high lifted. I live in Arizona so it is mostly desert trails. Some of the trails can get pretty ruff but not talking like boulders or anything obviously.
    Nice Tacoma by the way! :thumbsup:
  6. Apr 3, 2013 at 9:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    theres LT guys that still wheel their trucks on the rocks. They might have less clearance in the back with how their leafs are set up (under the axle, rather than over) but they have a hell of a lot of flex to make up for it.
    there's also guys that run full LT in the front and keep the rear mid-travel to stay on the trails
    but it depends on what kit you buy. with the longer arms, some front kits make the front too wide to go on narrow trails.
    also take into account a good LT will cost upwards of $10,000. and it's a hell of a lot more than just bolting parts up. you have a looooooooooooooooooot of reading to do. have fun
  7. Apr 3, 2013 at 9:44 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    One thing that wasnt mentioned yet is budget, how much are you willing to spend? Basically the front kits bolt on to any year truck of that gen (basically) and the rear is mostly cutom fab work. Double cabs have been LT'd.
    Expect to have 10K front and rear invested at a minimum to go LT.
    There are also 4WD kits that retain 4WD.
  8. Apr 3, 2013 at 9:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I've been waiting to see your links for suuuuuuuuuuuuch a long time :drool:
  9. Apr 3, 2013 at 9:56 PM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    Here is the build thread for my double cab. There are a few other built ones on here as well. It is awesome to have 3 other friends with you when you're ripping through the desert. I built mine to haul ass through the desert safely and comfortably and I daily drive it as well. Next step is the roll cage and its done.
    http://www.tacomaworld.com/forum/1st-gen-builds/209588-02-double-cab-build.html
    Heres is another one that is bad ass and 4x4
    http://www.dezertrangers.com/vb/dr-rides/124138.htm
  10. Apr 3, 2013 at 10:07 PM
    bobby632
    Bobby
    Tucson
    I never thought about making the front full LT and then doing the mid-travel in the rear. That's really smart because it brings the cost down quite a bit but still has the same effect, and I would have to do a ton of fab work. I'll keep in mind about the longer arms because there are quite a but of narrow trails out here in Arizona.
    I plan on putting a lot into overtime so I am not worried about the cost.
  11. Apr 3, 2013 at 10:09 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    LT front and mid-travel rear is a terrible end goal. Most of us who have that set up are "in progress" on LT'ing the rear end.
    The rear end will buck if you attempt to use the front end to its potential.
    You're better of mid travel front and LT rear.
  12. Apr 3, 2013 at 10:13 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Me Too :rolleyes: lol
    Not exactly the same effect and could be very dangerous thinking so. Could me the difference between a smooth ride and an Endo...
  13. Apr 3, 2013 at 10:18 PM
    bobby632
    Bobby
    Tucson
    After doing some reading and looking through pics I think Im gonna go full LT. It is just my style of off-roading and I love the look
  14. Apr 3, 2013 at 10:19 PM
    bobby632
    Bobby
    Tucson
  15. Apr 3, 2013 at 10:22 PM
    Mxpatriot
    Make sure to read all of the tacked threads in the LT section, it will get you 75% up to speed on exactly what LT is and what it entails. The other 25% you gotta earn the hard way lol.
  16. Apr 3, 2013 at 10:25 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Mid travel front, LT rear FTW :)
  17. Apr 3, 2013 at 10:45 PM
    bobby632
    Bobby
    Tucson
    http://www.youtube.com/watch?feature=player_embedded&v=656FwOwd1mw
    This just sold me. That is so bad ass!! Who doesn't want to go that fast and that high in the air with such a smooth landing. On some of those jumps the tires don't even leave the ground which is probably one of the coolest effects. Time to start reading and learning haha
  18. Apr 3, 2013 at 11:01 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    For 1st gen.
    Stock rear shock VS LT rear shock
    398D2FB3-3F51-40C5-8048-646A06F06AFB-105_35650b4bc99f1b5676f8d5d1adfd94af7126caf2.jpg
  19. Apr 3, 2013 at 11:06 PM
    bobby632
    Bobby
    Tucson
    One hell of a shock right there man
  20. Apr 3, 2013 at 11:06 PM
    bobby632
    Bobby
    Tucson
