Lube your driveshaft!!!!!
Discussion in 'Technical Chat' started by beechairplanes, Mar 21, 2009.
  1. Mar 21, 2009 at 10:30 PM
    beechairplanes
    beechairplanes [OP] Terrain
    Arizona
    01 tacoma 4x4 trd
    lift, yokahama geolanders,
    I have been battling a thumping noise in my 01 Tacoma when I come to a sudden stop or accelerate after braking. After some research and a timely post by jwscoot I have found the cause of the problem. The rear adjustable driveline has a grease zerk just for this purpose. Went to autozone to but a grease gun and synth grease at 10:00 tonight. Lubed the entire driveline and so far so good. Pass it around. What an easy fix to an extremely irritating problem. PS. The rear drive shaft to over 40 pumps of grease to start to show some movement. Thanks for yalls advice.
  2. Mar 22, 2009 at 4:02 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    can you post some pics on your repair? I have had the same problem in my 98 truck for years and no one seems to have figured it out.. I would not know what to lube back there.
    thanks for posting this!
  3. Sep 7, 2009 at 1:10 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I too wanted to Lube my driveshaft (09, V6, AT, DC, SWB) BUT, I could not find any zert fittings or any way to lube them? :confused:
    Should it be lubed? (or can it?).
    Yuma Taco,
  4. Sep 7, 2009 at 1:15 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  5. Sep 7, 2009 at 1:41 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    theres 5 grease zerks on the 05+ driveshafts
  6. Sep 7, 2009 at 1:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you referring to the slip yoke?
    If Yes....they need lubricated on the 1st gen trucks. However, too much grease can also cause problems (lack of it being able to 'slip').
    I'm not sure the 2nd gen trucks have a slip yoke lube point. The slip joint is covered up by a rubber boot and I haven't heard anyone who's actually found one yet. The grease zerk for the 1st gen trucks is behind the 'ear' on the driveshaft and the 2nd gens don't have one there.
  7. Sep 7, 2009 at 9:27 PM
    Yuma Taco
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    Please tell me where?????:help:
    I looked and felt and I could not find any on my 09, Pre-Runner, V-6, AT swb, Tacoma.
    I would love to lube something......:D
    Yuma Taco,
  8. Sep 13, 2009 at 7:50 PM
    DocD
    DocD Well-Known Member
    Mn.
    09 access cab
    I was under my "09" Access cab the other day and noticed that there were grease fittings on the (universal joints) drive shaft, I didn't notice any others, but will look the next time. now I am wondering just when they should be greased, Den
  9. Oct 3, 2010 at 6:30 PM
    Danro1009
    Danro1009 New Member
    Columbia, MD
    2001 4x4 Tacoma SR5
    I also had/am having a similar problem with an '01 tacoma 4wd double cab. I took it to Toyota and they said it was this grease issue. When they returned the truck, it was better but it did not last. I love this truck but this knocking sound/feel is really annoying! Anyone else have this problem or does anyone have any other advice? My understanding is that you can do damage to some bearing assemblies by over-greasing.
  10. Oct 3, 2010 at 7:28 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    there is only grease zerks on the 4x4s not prerunners.
  11. Oct 3, 2010 at 7:32 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    i have the same damn problem!!! very annoying
  12. Oct 3, 2010 at 7:41 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    If this is only happening when you are accelerating this is probably axle wrap. http://www.tacomaworld.com/forum/1st-gen-tacomas/108316-goodbye-axle-wrap-mod.html
  13. Oct 3, 2010 at 7:45 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i did a week ago.....black came out and mobil1 red went in.....i ran out of amsoil
  14. Oct 3, 2010 at 7:51 PM
    jjw1
    Jesse
  15. Oct 3, 2010 at 7:53 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Only 4x4's will have the Zerk fittings, not 2x4's. Kind of wish they would have came with them.
    You could take the connecting joints apart and lube. But I wouldn't worry about it, just drive.
  16. Oct 3, 2010 at 8:18 PM
    Yuma Taco
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    S.B. & BakoTruck;
    Thanks.
    Yuma Taco,
  17. Oct 3, 2010 at 8:20 PM
    crf69
    Ohio
    ummm yeah
    you wouldnt understand
  18. Oct 3, 2010 at 8:23 PM
    jjw1
    Jesse
    alright smart ass, i might be blonde but i aint that dumb...what is it the type of lube u used???
  19. Oct 8, 2010 at 6:46 PM
    c005jjc
    c005jjc Statistics are boring…until you become one!
    East Tennessee
    01 Prerunner DoubleCab SR5
    Axle wrap mod, Fumoto oil drain valve, Tinted windows
    I have a 2001 Tacoma Prerunner 4X2 and have dealt with the "driveshaft "clunk" for quite a while. It happens when I stop quickly at a traffic light and then when I take my foot off the brake...whamo! The first time it happened I thought someone had rearended me! My Prerunner does have 4 zerk fittings on the driveshaft and if they are greased properly, the clunk doesn't happen as often or as bad. When looking for a solution to this problem, I have found a lot of Tacoma owners are having this same problem for most all years of vehicles starting around 1999. Some have installed helper springs or traction bars to help with the softer rear springs - axle wrap...some have taken the driveshaft apart and sanded the splines and regreased and it helped...some have used really expensive DuPont Krytox GPL226 Grease and it helped...some have cut pieces of rubber and inserted at the rear of the transmission to stop some of the flexing...and the list goes on and on! You would have thought Toyota would have came up with a solution by now but I guess it would cost too much. I have found a this for Tundra's and Sequoia's...google T-SB-0067-09...so they have found a solution to the problem...but not for Tacoma's. I guess if we continue to buy and drive and buy the Tacoma's...we will need to pass along any information we can come up with that will minimize the "driveshaft clunk".
  20. Oct 10, 2010 at 7:49 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Mobil synth greas is Red, old goo is usually black. So as you pumping red grease in the U-joint , old blackened grease comes out
    Most of people use Mobil grease for u-joints, Toyota calls for lithium some crap grease that you should use on door locks only :D
