Lubing My Taco
Discussion in 'Technical Chat' started by grubburg, Apr 10, 2016.
  1. Apr 10, 2016 at 10:11 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Haynes says the lube should be done every 7500 miles. It says to grease the driveshaft universal joints and slip yokes. How many total spots are there on a 2014 taco 4wd v6? Kinda weak the manual doesn't say.
    Should any other suspension points be lubed? I get a little squeek going over some speed bumps.
    thanks guys
  2. Apr 10, 2016 at 10:14 PM
    Protosimian
    Protosimian Headbanger.
    Roger
    Where the Wild Things Are
    2012 MGM Sport
    Dents and scratches, and other stuff.
    :worthless:
    Sorry, I saw "Taco" + "Lube", you know how it is...being a smartass...:sorry:
    ODNAREM, JimboAnz and DrFunker like this.
  3. Apr 11, 2016 at 8:26 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Lots of threads on this site about this, including photos. Do a search of the 2nd gen forum ( hint: search for 'zerks').
  4. Apr 11, 2016 at 8:32 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When in doubt, lube the whole shaft ;) with a brush! No, don't. :p
  5. Apr 11, 2016 at 8:33 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Title got my interest, only to be let down once inside :notsure:
    Protosimian, ODNAREM and DrFunker like this.
  6. Apr 11, 2016 at 8:34 AM
    DrFunker
    DrFunker Well-Known Member
  7. Apr 11, 2016 at 10:28 AM
    grubburg
    2019 TRD OR MT
    i saw that post. Are those the only ones? Nothing in the front suspension?!
    "zerk" = "great fitting"? Haynes doesn't use that term.
  8. Apr 11, 2016 at 10:50 AM
    tan4x4
    Rick
    Folsom, CA
    There should be a zerk at each end of the front DS (at least on my 1st-gen there is)
    I guess 'zerk' is an old term, the FSM likely says 'grease fitting'.
  9. Apr 11, 2016 at 11:01 AM
    grubburg
    2019 TRD OR MT
    How much was your FSM and how do you like it? The Haynes is pretty solid ($30) but could be a little more detailed for newbs.
  10. Apr 11, 2016 at 2:05 PM
    tan4x4
    Rick
    Folsom, CA
    If you plan on keeping your rig for many years, and doing your own repairs, I highly recommend getting the FSM for your specific year. I have the 1999 FSM for my '99, but the 98-00 years are pretty much the same, mechanically at least.
    For 1999, the manual came in 3 volumes, including a separate one for electrical diagrams.
    I bought each one separately, online, and paid a total of around $150.
    I also have a Haynes manual which I keep in the truck.
  11. Apr 14, 2016 at 8:56 PM
    grubburg
    2019 TRD OR MT
    so i got under there and the picture of the middle joint in the Haynes doesn't match the actual 2014 drive shaft.
    i found a total 4 zerks. one by the tranny, one in the middle, one at the end by the axel.
    anyone with a 2014 find anything different?
  12. Apr 18, 2016 at 8:17 PM
    grubburg
    2019 TRD OR MT
    anyone?
  13. Apr 20, 2016 at 9:25 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    My 2014 had 5 as stated. 2 up in the front driveshaft and 3 for the rear driveshaft.
