Lubing UCA's?
Discussion in 'Suspension' started by ETaco23, Feb 14, 2009.
  1. Jul 3, 2009 at 8:33 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    Yea they have been on for about 10 months.
  2. Jul 3, 2009 at 8:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok..Grease them until they pop. You should be fine. :)
  3. Jul 3, 2009 at 8:35 PM
    bermise
    Houston
    08 TRD off road
  4. Jul 3, 2009 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Jul 3, 2009 at 8:37 PM
    bermise
    Houston
    08 TRD off road
  6. Jul 3, 2009 at 8:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I wouldnt use them. I have only srayed my uniballs 2 times in about 2 years. And I dont clean them.
  7. Jul 3, 2009 at 9:23 PM
    vwguy60
    vwguy60 Well-Known Member
    Southern California
    2009 TRD Sport DC LB
    Toytec Ultimate Lift Kit, TC ucas, TRD CAI, powder coated OEM tube steps, powder coated TRD skid plate.
    I couldn't find silicon grease but I didn't look very hard. I also used Mobile 1 grease (synthetic and red in color). I figured I could still use it on everything else so I went that route rather than having to have two grease guns. I like it cuz it matches the red urethane bushings, not a very technical reason but it is a great product.
  8. Jul 3, 2009 at 9:35 PM
    bermise
    Houston
    08 TRD off road
  9. Jul 3, 2009 at 9:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use a Dry Teflon Spray lube.
  10. Sep 4, 2009 at 8:39 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Thread revival...
    Hi Chris,
    TC recommends teflon based grease for the sleeves and bushings. Why do you prefer Mobil 1? Is it because grease is just grease or it has some advantages?
    I am planning to install the UCA this weekend. Your opinion matters.:)
  11. Sep 4, 2009 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never heard a peep outta my UCA's or any I have installed when I have used Mobil 1 grease. Not sure of the differences between it, and a Teflon based grease, but TC said Mobil 1 would be fine, and it has been so far. My personal reason for useing Mobil 1 grease, is because of its High temperature tollerance. I use it on just about everything that needs to be greased. :)
  12. Sep 4, 2009 at 9:05 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Mobil 1 specs show -40 F to +302 F. while the teflon based boast of -65 F to +500 F. Teflon based seems to better in this aspect, yet you've been using Mobile 1 for some time now, so I trust that it works fine. I guess I don't need teflon grease. Thanks for your prompt response.
  13. Aug 11, 2010 at 12:46 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
  14. Aug 11, 2010 at 1:08 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yep! thats the one I use.
  15. Aug 11, 2010 at 1:32 PM
    #35
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    I don't mean to thread jack but I have a question.
    My stock UCA bushings are squeaking like crazy. I'm planning on taking the UCA off, cleaning the bushings really well and lubing them before re-installing them.
    Should I use the Dry Teflon lube mentioned, or Mobil1 Synthetic grease?
    Thanks for the responses.
  16. Aug 11, 2010 at 1:45 PM
    #36
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    this is the stuff i use on my UCAs, the synthetic spray for the uniballs and the grease for the bushings
  17. Aug 11, 2010 at 2:49 PM
    #37
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For the bushings, I bought some Prothane brand teflon grease from Jeg's.
    Energy Suspension reccommends teflon grease(milky white & tacky) or marine grease in lieu of.
    Mobil One should work fine; I just have OCD when it comes to these things.:eek:
    For the uniballs, I bought the DuPont teflon spray.
  18. Aug 12, 2010 at 8:17 AM
    #38
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    My UCA squeaked a lot with Mobil 1. I replaced the grease in the bushings and the squeak is gone!;)
  19. Aug 12, 2010 at 10:33 AM
    #39
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  20. Aug 12, 2010 at 2:17 PM
    #40
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    perfect
