Lubricating TC UCAs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Future55, Jan 9, 2011.
  1. Jan 9, 2011 at 1:25 PM
    Future55
    Future55 [OP] Well-Known Member
    Oahu
    2010 4x4 DC TRD Sport
    Weathertech Mats, AFE Stage 2 SI Pro Dry S CAI, TRD Exhaust, Access LE w/ Pop'n lock, 17" XD Revolvers, 285/70/17 Duratracs
    Im having a shop install my OME kit with TC UCAs tomorrow. Ive read all about the squeaking and so far ive gathered that i shouldnt use an oily lubricant or pb blaster on the uniball, i should use dry teflon spay. Got it..what about for the bushings? Same thing?
    Also, anyone think the shop would know to do this and what to use? Or should i just pick up the supplies myself and give it to them?
    On a separate note, any words of advise i should give the shop tomorrow morning regarding the install of either the OME or TCs? So far all i can think of is the lubrication, and the fuels lines on the driver side (correct?).
    edit: I know this should be posted in the suspension forum; however being that the install is happening tomorrow i figure id try and get the most views as possible. :)
  2. Jan 9, 2011 at 1:32 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You grease the bushings while they are off. Slide them in the arms. Once installed, you use a grease gun and attach it to the zerks
  3. Jan 9, 2011 at 1:33 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Stupid phone.
    .....then you fill her up. There is no need to grease the uniball at install. I've had mine on a year and a half. Original greasing at install as said and no squeaks.
  4. Jan 9, 2011 at 1:33 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Chances are they will not know what to use, so you should bring the correct stuff with you. On the bushings, most people use Mobil 1 grease.
  5. Jan 9, 2011 at 1:34 PM
    JDMcQ
    Be careful not to over grease the zerks, it is real easy to blow the bushings out.
  6. Jan 9, 2011 at 1:34 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    As for the fuel lines, they don't need to know anything except for not to break them. Oh and I used mobil 1 grease for the bushings.
  7. Jan 9, 2011 at 1:38 PM
    Future55
    Oahu
    So i shouldnt have them grease the uniball tomorrow? Im heading down to school this week so i wont be able to grease it again until maybe March, if not then the end of May.
    And i should pick up some Mobil 1 grease for the bushings and zerks?
  8. Jan 9, 2011 at 1:41 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea. A tube of it is like 6 bucks at autozone.
    And you don't have to lube the uniball. Like I said mine still don't squeak. TC ucas are great. The stuff I plan to use if they do is in a spray can. You just spray it on.
  9. Jan 9, 2011 at 1:55 PM
    JDMcQ
    I spray mu uniballs every month or so, just to be sure. Throw a can of the dry film in your truck for when you are away from home if you are worried about it.
  10. Jan 9, 2011 at 4:07 PM
    Future55
    Oahu
    Yea i could do that, thanks for the help guys, picked up some mobil 1 a few minutes ago.
    For the uniball lube, i can just spray that on myself without taking anything apart? On top and below?
    Also, any more tips i can give the shop in regards to the lift & UCAs?
  11. Jan 9, 2011 at 4:09 PM
    JDMcQ
    Spray it on the top and bottom of the exposed uniballs. No need to remove anything, not even the tire.
    The lift is pretty easy, they shouldn't have any issues. They will probably have to bend the pinch weld inside the fender to get the UCA bolt out.
  12. Jan 9, 2011 at 4:13 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Use some tri flow dry lubericant on the uniball. The bushings that TC use call for a teflon based grease but I was unable to find it so I used the tacky red Mobile 1 grease and havent had a squeak or problem sense.
  13. Jan 9, 2011 at 4:13 PM
    Future55
    Oahu
    Awesome! Thanks man. Yea, i assume they know what they are doing because they do lifts all the time, its just they havent heard of OME so im a bit weary.
  14. Jan 9, 2011 at 4:15 PM
    Future55
    Oahu
    Yea i think i should be able to pick some up down at school, but for the install tomorrow im just gonna hand them the mobil 1 i picked up for the bushings and zerks.
  15. Jan 9, 2011 at 4:33 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ooo one more thing. You should buy new zerks from autozone. It is super super hard getting them to thread into the holes. Autozone has some that go on super easy. Will save the shop time and also prevent them from breaking one or crossthreading it.
  16. Jan 9, 2011 at 10:17 PM
    Future55
    Oahu
    Hmm...im taking the truck in tomorrow at 9, should i just risk it and hope they are able to do it? Whats the worst that could happen, i get a call and i have to run to autozone to pick some new ones up? At this point i think taking the risk is my only option. I go back to school tomorrow so the lift can only be done tomorrow and hopefully in a short amount of time..
  17. Jan 9, 2011 at 10:27 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    If they are a decent shop they should be able to figure it out. If they break it it's on them.
