Lucariorunner's autocross rav4 build.
Discussion in 'Other Builds' started by Lucario Runner, Jan 12, 2019.
  1. Jan 12, 2019 at 8:54 PM
    Lucario Runner
    Lucario Runner [OP] Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    This is the build of my first car, I still own it. My mom had bought this new in 97. Its a 4door automatic. Around 2005 it became my first car. Not the car I would have chosen but it was great as it only had 120hp and all weight front bais with no rear sway bar. It has taught me much in terms of weight transfer and understeer when I was driving on my own.
    Sadly there wasnt much mods for power at the time and a year or so later I got my 4runner and kept this as a spare since the resell value was super low at the time. Glad I kept it as I keep hearing a consistent thing where people much older than me keep saying they wished they'd kept their first car. So my intentions are to make this into a good autocrosser. Go back to maybe March of 2018 and it was super cold in San Antonio and I had let me uncle borrow it since his 03 Silverado did not have a working heater. A few days after he had backed into a pole.
    So for awhile I was unsure what to do. I went to try a get a door but its get harder to get. I went to a pick and pull and got the 'most good' rear door I could find in the whole city.
    I didnt do much since then as it's at my uncles house and hadnt had time to deal with it. Recently I cut the old door off as the lock was both broken and in a bind.
    So now im going to paint the green door so it doesnt look too roadkill. Once I have it back at my house ill go though to make it run might throw in a new gas tank just because and swap in a 3sgte and a manual transmission. Id like to unroadkill my rav4 this year. We shall see right @Torspd?
    Torspd, Athlaos, Slashaar and 2 others like this.
  2. Jan 13, 2019 at 1:51 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    So step 1.2 into unroadkilling my rav4 is to replace the battery. I had bought this brand new last year to make sure the rav4 would start everytime my uncle needed it. Guess we can see how that turned out. I put in a thing of red line fuel system cleaner. I also took the battery out to replace it. I clean the terminals and applied some grease for protection. For now I'll get a new battery and replace the fuel filter, spark plugs and wires, check the coolant i had replaced the radiator and t stat last year so it should be ok. And lastly the engine oil and trans fluid. Once I have it running ill check the brakes.
    Slashaar likes this.
  3. Jan 16, 2019 at 8:39 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Got the same gen rav4 myself. Mines a 2000. Good little car.
  4. Jan 17, 2019 at 11:45 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I agree. The lack of weight makes it feel so much fun even though your not going fast.
  5. Jan 17, 2019 at 9:23 PM
    markm0311
    2000 Toyota RAV4
    It really does. I pulled the back seats recently going to make a drawer system for the back of it. I really like that I found one that was taken care of and had a mint interior. I also like your back hatch replacement documentation. I’d like to get a Molle panel or something made up to take the place of the plastic trim piece
  6. Mar 15, 2019 at 12:52 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    As an update on this kinda project I got a new battery and fluids for the car. Ordered a gates timing belt kit and new brake lines, rotors and pads. Wantee to work on it this weekend however work got priority.
  7. Nov 4, 2021 at 11:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This little thing needs some lovin'.
  8. Nov 4, 2021 at 11:43 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    it do. I'll toe it 2 ur pad for work. ;)
  9. Nov 4, 2021 at 11:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It has that many spare parts that it needs a trailer to haul them? It doesn't drive?
  10. Nov 4, 2021 at 12:02 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    probably not.
