Lucas 85w-140 for transfer case?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtmudrunner, Apr 29, 2018.
  1. Apr 29, 2018 at 7:24 AM
    mtmudrunner
    mtmudrunner [OP] Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I know ECGS recommends it for the difs, has anyone used it in the transfercase or is it too heavy? I got a good deal on a case.
    Case not csse :annoyed:
  2. Apr 29, 2018 at 7:53 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I wouldn't. I put what toyota recommends. Will it hurt anything?........I doubt it
    mtmudrunner[OP] likes this.
  3. Apr 29, 2018 at 12:46 PM
    badger
    badger Well-Known Member
    07 SR5
    NOT a good idea! The transfer case uses an internal pump to lubricate it, with a very fine filtering screen. A higher viscosity lube would likely starve the case of proper lubrication. I would also not use any oil additives. I have seen some plug this screen. A good synthetic oil in the proper viscosity is best.
    Norton likes this.
  4. Apr 29, 2018 at 1:42 PM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    That's what I needed to know thanks
  5. Apr 29, 2018 at 2:14 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Is it actual fact or just your opinion that the higher viscosity is bad for the pump? Not trying to start anything, just curious cause I run Lucas 85W140 and I’m wondering if I absolutely need change it.
  6. Apr 29, 2018 at 2:15 PM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    How long have you been running it?
  7. Apr 29, 2018 at 2:38 PM
    jowybyo
    Joe
    Baltimore, MD
    About 20k miles.
  8. Apr 29, 2018 at 3:04 PM
    badger
    07 SR5
    All I know for a fact is that the screen is small and very fine. It is meant for a thinner oil. A thicker oil will have a harder time getting through, which means less oil. The problem is, we won't know for SURE until yours fails. If it were mine, I would change it.
  9. Apr 29, 2018 at 3:08 PM
    jowybyo
    Joe
    Baltimore, MD
    The more I think about it the less I’m worried about it. I swapped to a FJ t-case, it was only $250. I’ll swap in another if it blows up I guess. I’ll be sure to report back if it goes to shit.
    SC2SC and BassAckwards like this.
  10. Apr 29, 2018 at 3:11 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    why would u want to use a 85w140?
    Norton likes this.
  11. Apr 29, 2018 at 3:55 PM
    jowybyo
    Joe
    Baltimore, MD
    I’m not sure now. I think I remember reading something where they did a tear down one a transfer case using 75W-90 vs 85W-140 and the heavy oil one looked better. I’m having trouble finding the thread. When I regeared I just went ahead and changed all the gear oils to 85W-140.
  12. Apr 29, 2018 at 4:06 PM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    Using the same fluids in all three is what I would like to do but it's not a deal breaker I'm going to use the 85w-140 in the front and rear but still unsure on the t-case.
  13. Apr 29, 2018 at 8:34 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    For whatever it’s worth I’m aiming to go with 85w-140 in my LSD rear on my 07 taco and stay with 75w-90 in the t-case and front diff when I change them all again at 90k. I have used 80w-90 in the rear diff up to this point, I tried 75w-90 in the rear diff once but it chattered with synthetic in it...even with extra lsd additive. Went back to conventional 80w-90 and a few oz of friction modifier, all is good.
  14. Apr 29, 2018 at 8:43 PM
    badger
    07 SR5
    I have been using 85w110 Redline in the rear diff for some time, but 75W-90 in the front. The front never sees the heat or the speed that the rear does. I don't use hypoid gear oil in my manual transmission or transfer case. I use Redline MT-90 in both. My transfer case has over 200,000 miles on it with zero issues. It's an FJ twin stick transplant.
    The transfer case never sees anywhere close to the heat that the rear diff does, nor does it see the pressures generated by hypoid gears, so I see no need at all for the high viscosity oil.
  15. Apr 29, 2018 at 8:59 PM
    badger
    07 SR5
    The needs of all three are different. The 85-140 is fine in the rear. The front doesn't need it at all, and the T-case is a completely different type of gear box. It's a small expense every couple of years, and the left overs will keep till the next change. I don't want to be the voice of doom, but I see only potential downside to using 85w-140 in the T-case, no upside.
  16. Apr 30, 2018 at 9:18 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    heavier oil can affect MPG in the diff
    Heavier oil does not mean better protection
    in cold climates, heavy oil can be bad or not let thins work until warmed up
    BillsSR5 and Norton like this.
  17. Apr 30, 2018 at 9:48 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    CHALLENGE
  18. Dec 10, 2018 at 6:48 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Do you still use the 85w140 in the tcase? Trying to decide if I wanna stick with all the same oils
  19. Dec 10, 2018 at 7:03 PM
    jowybyo
    Joe
    Baltimore, MD
    Yea
  20. Dec 11, 2018 at 10:29 AM
    96carboard
    96carboard Well-Known Member
    If you like to be stuck in 2wd, then go ahead. But if you like to be able to use 4wd, keep it to 90.
