lug conversion
Discussion in 'Street Trucks' started by Dr.I.B.Rollin', Jan 23, 2016.
  1. Jan 23, 2016 at 9:37 PM
    Dr.I.B.Rollin'
    Dr.I.B.Rollin' [OP] Member
    joshua
    2001 double cab tacoma
    does anyone know what I would have to do to change my truck over from 6 lug to 5 lug. its a 2001 double cab.
  2. Jan 23, 2016 at 9:38 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  3. Jan 23, 2016 at 9:41 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    This is your THIRD thread on this today. Maybe just accept the good answers posted in your other threads.
  4. Jan 23, 2016 at 9:46 PM
    Dr.I.B.Rollin'
    joshua
    Well if there were any good answers maybe I would. But, all I get is criticizism.
  5. Jan 23, 2016 at 9:51 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    "Way easier and cheaper to have the wheels re-drilled for a 6lug."
    "you can probably get some sort of adapter/wheel spacer that will convert from a 6lug pattern to a 5 lug pattern."
    "Bore size, possible need for center hub ring-adapters would require further investigation, before considering the below spacer/adapter find:
    http://www.amazon.com/Wheel-Adapter-Lug-5-5-4-5/dp/B008L4NAFE/"
    Those were some pretty good answers I think. And if they aren't the desired answers, you can always BUMP a thread, which sends it to the top for more people to read and answer your question. Also, my bad, this isn't your third thread on this, but it is your second.
  6. Jan 23, 2016 at 9:55 PM
    Dr.I.B.Rollin'
    joshua
    I'm not trying to use wheel spacers. I was thinking I could take the rear axles and and front spindles and rotors off of a 5lug truck and switch it all out. I'm just trying to find out if that's possible before I try to do it.
  7. Jan 24, 2016 at 1:09 AM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    after having just taken apart my front suspension, it looks like you can just get the brake rotors and lugs from a 5 lug donor. As for the rear, I don't know what it looks like but doing a 4 lug to 5 lug conversion on a 240sx you might be able to get the rear hubs and brakes off of the same donor. I don't know if that helps.
