Lug nut question
Discussion in 'Wheels & Tires' started by lickitysplit, Jul 4, 2016.
  1. Jul 4, 2016 at 1:12 PM
    lickitysplit
    lickitysplit [OP] Well-Known Member
    john
    2013 Tacoma Access Cab Sport
  2. Jul 4, 2016 at 1:14 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    That truck has studs. Contact your vendor for clarification...
  3. Jul 4, 2016 at 1:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Nope. You truck still has threaded studs needing lugnuts, like all normal vehicles on the road except the Germans.
    Lugnuts can come in similar small-diameter spline-drive design: https://www.amazon.com/Gorilla-Automotive-21133BC-Diameter-Thread/dp/B001O0AMZS
    If the wheel mounting pad is thick, you may need extended-thread lugnuts: https://www.amazon.com/Gorilla-Automotive-21133ET-Extended-Diameter/dp/B001O0AO0Q
  4. Jul 4, 2016 at 1:24 PM
    lickitysplit
    john
    Thank you I'll send them an email..
