Lug nuts - how many turns?
Discussion in 'Wheels & Tires' started by JC47, Mar 25, 2012.
  1. Mar 25, 2012 at 7:50 PM
    JC47
    JC47 [OP] Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Hey guys, did a quick search and couldn't find anything. Just wondering what the minimum number of turns on a lug nut would be to be considered safe. With my stock sport wheels the lug nuts turned around 12 times before they were tight, on my aftermarket wheels and new lug nuts I get between 6 and 7 turns before they are tight. Just want to make sure it's still safe. Thanks for any info!
  2. Mar 25, 2012 at 8:01 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    Torque is your friend and it should be about 80-85lbs. Please don't rely on "how many turns til tight"
  3. Mar 25, 2012 at 8:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The issue isn't torque, his issue is thread engagement, and it is a valid concern.
    80ft/lbs with only 3 threads engaged is not good.
  4. Mar 25, 2012 at 8:04 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    Longer shanks on the nuts, or longer studs.
  5. Mar 25, 2012 at 8:05 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    This if the threads are cross threaded then that's no good. I usually start it by hand and then pull it down with the t-bar until it's nice and tight.
  6. Mar 25, 2012 at 8:05 PM
    JC47
    British Columbia
    Yes, I have them torqued correctly, but I would think the number of threads would come into play as well. If you are at 85lbs but only have 2 threads holding, I don't think that will cut it. 7 threads seem reasonable, but I was just wondering if there is an actual minimum to go by. Thanks for the responses.
  7. Mar 25, 2012 at 8:09 PM
    Fightnfire
    Marysville, WA
    I jumped to conclusion, and reading comprehension failed me. Sorry!
  8. Mar 25, 2012 at 8:12 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Agreed... and that works fine for stock wheels and stock lug nuts.
    But he's got wheels that are thicker than stock, or is using the cheapie wheel spacers that move the wheel 1/2" or less.
    That is pushing the lug nuts out and creates two issues....
    The nut is not fully engaged (and I agree that 7+ threads is enough to hold the wheel), but it is also putting the stress riser from the end of the lug nut's shank in the middle of the stud. The end of the lug nut should be within a couple of threads of the hub face.
    There is more than one reason that the "plate" type wheel spacers are not a good thing.
  9. Mar 25, 2012 at 8:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I did the same on first read... then on re-read I thought "WTF? He's only threading them on halfway before reaching torque?"
  10. Mar 25, 2012 at 8:27 PM
    JC47
    British Columbia
    I'm actually running aftermarket wheels (dick cepek dc2's), which have 4" backspacing and -12 offset. The lug nuts are a different style than the stock ones, so that's probably the main difference. Rich91710 - your post makes sense about having the end of the lug nut close to the hub face instead of the middle. I'm going to go take one off just to see how close it is.
  11. Mar 25, 2012 at 8:40 PM
    JC47
    British Columbia
    Hard to tell, but it looks like the end of the lug nut is about 3/4's of the way down the stud towards the hub. I'll just stop by a tire shop tomorrow to make sure I'm safe.
  12. Mar 25, 2012 at 8:46 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    I thought it was suppose to be 90ft lbs?
  13. Mar 25, 2012 at 8:48 PM
    Fightnfire
    Marysville, WA
    I seem to remember lug nuts should grab minimum their width in thread. So, a 1/2 lug should grab 1/2" of thread. That should be about 6-7 turns.
  14. Mar 25, 2012 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I would get longer studs installed. If Toyota decided 12 turns was enough and designed a margin of safety into the design, then you're probably still okay with 7. But I wouldn't risk it.
  15. Mar 25, 2012 at 8:54 PM
    JC47
    British Columbia
    I just did a bit of research and found this answer come up quite a bit. According to this I should be safe, but I'll still double check with a tire shop for peace of mind.
  16. Mar 25, 2012 at 9:18 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    90 is fine.....
    I use 100ft lbs on all my vehicles and have for many many years. ;)
  17. Mar 25, 2012 at 9:18 PM
    JC47
    British Columbia
    Found this on another website:
    . Check the lug nut thread engagement. Every stud must be long enough to thread into the lug nut a legnth at least equal to the stud diameter. For example, a 1/2" thread diameter must thread into the lug nut at least 1/2". Check for this problem on every stud, some may be of different lenghts. Less than one stud thread diameter engagement is unsafe and will cause loos of lug nut torque. IF YOU DO NOT HAVE PROPER THREAD ENGAGEMENT, DO NOT INSTALL WHEELS.
  18. Mar 25, 2012 at 9:23 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    go to a tire shop and get a different style lug nut with the proper shank
  19. Mar 26, 2012 at 8:20 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    I recently bought wheelspacers form motorsport tech and they said you want at least 8 turns on the lugs for it to be safe.
    I'd recommend getting some ET (extended thread) lug nuts for your aftermarket wheels. Or some longer studs if you want... But apparently "8" is the magic number.
    FWIW, torque is 83 ft lbs
  20. Mar 26, 2012 at 11:32 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
