Lug Nuts
Discussion in 'Wheels & Tires' started by ajracing, Dec 8, 2017.
  1. Dec 8, 2017 at 2:16 PM
    ajracing
    ajracing [OP] Well-Known Member
    aj
    Houston, Tx
    2018 tacoma
    Just ordered a set of TRD Pro 17" wheels from dealer and buying told i need a set of $167.00 lug nuts, is there correct?
  2. Dec 8, 2017 at 2:17 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Spline lugs? You can get them cheaper anywhere else
  3. Dec 8, 2017 at 2:18 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    You are bidding a complete set (2 front & 2 rear) of Genuine Toyota / TRD Factory 4Runner BLACK Finish 17" Alloy Wheels with Center Caps - 1984 to 2018! These are new and unused (PTR20-35110-BK) - they are not take-offs and they are not grey painted black! This is the same style featured at SEMA. I have access to a few sets but I do not know how long I will be able to obtain them! Features include:
    • Unique
      • Made by TRD for Toyota.
        • Low pressure cast aluminum.
          • 17" x 7".
          • 4mm offset.
          • 6 x 139.7 bolt pattern.
      • Rim is TPMS compatible (stock 20 degree sensor only).
    • Toyota Recommended Tires
      • Stock OE 17" Tires P265/70R17 113S
      • Bridgestone Dueler H/T D684 II A/S
      • Dunlop Grandtrek AT20 A/S
    • What you receive
      • 4 rims.
      • 4 center caps.
    • What is not included
      • TPMS (note above).
      • Tires (note above).
      • Lug nuts - this is important!
        • Stock lug nuts do fit.
        • You will reuse your existing lug nuts.
  4. Dec 8, 2017 at 2:18 PM
    ajracing
    aj
    Houston, Tx
    2018 tacoma
    Not sure.
  5. Dec 8, 2017 at 2:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Look above it's the last sentence you reuse your stock lugs
    Siblue likes this.
  6. Dec 8, 2017 at 2:23 PM
    ajracing
    aj
    Houston, Tx
    2018 tacoma
    I got it, thanks. any reason other then them trying to make money, why they would tell me that?
  7. Dec 8, 2017 at 2:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You stated it to make money, this the wheel you bought?
  8. Dec 8, 2017 at 2:25 PM
    ajracing
    aj
    Houston, Tx
    2018 tacoma
    that's it, thank you.
  9. Dec 8, 2017 at 2:26 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Shwankin407 likes this.
  10. Dec 8, 2017 at 2:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  11. Jan 25, 2018 at 8:12 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not sure as I don't know if those are an actual OEM wheel, or a copy in the style of the wheel. Is it a good price I guess so, but I like to stay OEM, not OEM Style as those are 16x8 and I believe OEM is 16x7. Maybe somebody else will chime in on it though
    DesertTaco4x4 likes this.
  12. Jan 25, 2018 at 8:14 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That's a tough one to explain while in driving @nd4spdbh knows a thing or 2 about offsets.
  13. Jan 25, 2018 at 8:17 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  14. Jan 25, 2018 at 6:25 PM
    Nick13
    Nick13 Well-Known Member
    Dominic
    2017 sr
    I was told I need a $120 set of trd spline lugs by the stealer today. Other dealer sites say the shank style lugs will work. I have steel wheels now n they use acorn style
    Tremors834 likes this.
  15. Jan 27, 2018 at 6:52 AM
    Tremors834
    Tremors834 Huh?
    Gene
    Las Vegas, Nevada
    2018 Offroad DCSB
    Did the lugs from the steel wheels work?
  16. Jan 27, 2018 at 4:17 PM
    Nick13
    Dominic
    2017 sr
    I'm still waiting for the wheels. However I do not believe they will. It is the regular acorn style for steel wheels.
  17. Jan 27, 2018 at 4:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    This is right in the listing for the 17 inch SEMA Wheels posted above.
    This listing is for a complete set of 17 inch Black TRD Pro wheels for 4Runner, FJ Cruiser, & Tacoma. OE tire size for 4Runner/FJ is P265/70R17. OE tire size for Tacoma is 265/65R17. Center cap is included. These wheels use the OE-style flat seat lug nuts with washers attached. If you currently have factory aluminum wheels, your lug nuts should work. If you have factory steel wheels or aftermarket wheels you will need new lug nuts (not included). TPMS sensors will transfer from OE aluminum wheels.
