lumbar goes "down" after a few days?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Jan 7, 2011.
  1. Jan 7, 2011 at 3:25 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i've noticed that my lumbar support, which i use fully adjusted "out", will go down after a week or so of driving in the truck. then, i'll have to turn the wheel counterclockwise all the way to get it back to fully out.
    does this occur for anyone else? i am under the impression that it should just stay where i set it...
  2. Jan 7, 2011 at 3:33 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Are you sure you don't have a leprechaun thats adjusting it when you're not in the truck?
    Mine stays in place.
  3. Jan 7, 2011 at 3:35 PM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    yea, i've noticed too. i think whenever you get in or out, you press against it, pushing it back into the seat. sometimes I feel it "pop" back a few notches when i sit down.
  4. Jan 7, 2011 at 3:37 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    Same here, it is so gradual over time though.
  5. Jan 7, 2011 at 3:52 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    hey guys saw this thread and it reminded me of work. im a toyota tech, i actually just replaced a whole driver's seat in an fj yesterday because the ratcheting up/down lever on the seat slowly lowered itself over time... it eventually broke and the lever doesnt do anyhting. it was warranty so we replaced the whole seat... but theres a tsb for it too on the fj... it was replaced under warranty. its caused just like JDMcompliant said by "sliding" out of our seats. everyone does it... im not saying go to ur dealership and demand a new seat, cuz it wont make a difference. and they wont give u a new seat anyways ha. i just wanted to give u guys some insight on the issue i've seen.:thumbsup:
  6. Jan 7, 2011 at 3:58 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    mine does this too. i got tired of adjusting it back so i don't use it anymore.
  7. Jan 7, 2011 at 6:13 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    thanks guys. so it's normal....
    the reason i asked was mainly because the first night i had this truck, the lumbar broke! i went to adjust it, spun it toward the front two spins and it sorta popped then the adjuster was very loose and screeched. i brought it in and they ordered some parts. they actually took the seat apart and repaired it as opposed to swapping the whole seat - i was surprised it was serviceable, but it was.
    it works fine, but i notice it goes down after a week or two and when it's all the way down if i lean to the right and back it'll sorta pop in the seat a bit. it all works ok though and apparently seems to be somewhat normal.
    there should be some sort of locking mechanism on it.
  8. Nov 6, 2011 at 12:22 PM
    RCNG FAN
    RCNG FAN Active Member
    I'm having the same problem! How much was it to fix yours? Thx!
