Made in Colorado
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrrumzy, Dec 14, 2018.
  1. Dec 15, 2018 at 2:07 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Any better pictures of the mounts? If it’s attaching to the factory holes in the double cab roof, I’m having a hard time picturing what is different.
  2. Dec 15, 2018 at 2:07 PM
    jowybyo
    Joe
    Baltimore, MD
    tcjacado[QUOTED] likes this.
  3. Dec 15, 2018 at 2:28 PM
    Horger12
    Horger12 Well-Known Member
    Albuquerque, NM
    2017 Barcelona Red OR-DCSB
    5100s, Toytec AAL, Falken Wildpeaks, CaliRaised Ditch Pods, BAMF Sliders and Bed Bars
    Both Prinsu and Frontrunner Outfitters use the same mounting method of using the factory holes as well. The difference is they use the laser cut side rail to mount them to the roof, then their crossbars are bolted to that. RMR uses separate brackets that attach the crossrails to the roof with the side panel attached to the crossrails separately. It doesnt make contact with the roof at all.
    https://frontrunner.thirdlight.com/file/42477061253
  4. Dec 15, 2018 at 2:31 PM
    jowybyo
    Joe
    Baltimore, MD
    Gotcha. So the RMR is limited to only two crossbars then?
    Edit: three cross bars? And side plate is just for show.
  5. Dec 15, 2018 at 2:41 PM
    Horger12
    Albuquerque, NM
    You can put more than three on but those three are what distribute the weight. Additional bars attach to more bolt holes on the side plate similar to Prinsu.
  6. Dec 20, 2018 at 3:53 PM
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    RMR's mounts
    doublethebass and jowybyo like this.
  7. Jan 14, 2019 at 8:13 PM
    OkieYota
    OkieYota Unknown Member
    ‘18 TRD OR DCSB Cement
    None yet
    Any pictures from above? I see you can adjust all but 3 crossbars but I have a moonroof and would like to not have a crossbar directly above it. I guess I could turn the supports more parallel to the side rails . Also do the side rails shake without support on the side rails down lower by the cab?
    I like this better than the prinsu as the side rails go down further but I would only want to buy if I could get a matching rack for my camper shell .
  8. May 9, 2020 at 11:08 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Did RCI stop making these roof racks?
