MAF reading 3.4g on my 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Feb 29, 2020.
  1. Feb 29, 2020 at 4:47 AM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Does anyone know why on earth my MAF is reading 3.4g at idle? As far as I know they should match the engine displacement. Can anyone verify this? Thanks!
    Black DOG Lila likes this.
  2. Feb 29, 2020 at 4:52 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    What year?
  3. Feb 29, 2020 at 5:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Check his profile, says 99.
    Although I'm not sure what a pre runner 4x4 is. Conversion?
  4. Feb 29, 2020 at 7:12 AM
    Rachelsdaddy
    Southern NH
    Yeah, it’s a 99 2.7 PreRunner. I have been chasing drive ability issues for years. High +10 ltft. If I am correct and this should read 2.7 grams per second either I have the improper maf (from a 3.4) or the ecu is incorrect for the truck. If the ecu thinks it’s getting 3.4 g of air seems to me it would certainly be trying to add fuel. The maf that’s in there supposedly came from a 2.7, bought it from a boneyard online. Any techies know for sure?
  5. Feb 29, 2020 at 7:29 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I'd start by changing that sock you've been using for a gas cap and the burned out CEL lightbulb.
    That S2 O2 diode under passenger seat isn't helping driveability either.
    Clean the MAF with a stiff wire brush and Drano liquid if you're feeling adventureous.:bananadead:
    Wyoming09 likes this.
  6. Feb 29, 2020 at 7:41 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
  7. Feb 29, 2020 at 7:49 AM
    Glamisman
    Glamisman Well-Known Member
    I understand your thinking... Spitballing and thinking out loud here, if there was a slight vacuum leak the O2 sensor would compensate but the g/sec would be lower... is the idle normalish, not over 800 rpm? The 4 cylinders seemed to be different throughout the years... some have a MAP sensor some dont. The brake vacuum booster is often overlooked for vacuum leaks... squeeze the hose and look at STFT for an improvement. Raise the rpms slowly and hold at say 2k and look at STFT... if it improves toward 0 then there is definitly false air somewhere. What does the IAT show... this is built into the MAF as far as I know. PCV valve OK?
  8. Feb 29, 2020 at 8:46 AM
    Rachelsdaddy
    Southern NH
    Can you guys re-read the original post? I know my O2 is correct. I’d like to know how many grams per second is a 2.7 supposed to read at idle. I’m fairly sure it should be 2.7. This is where I’d like to concentrate. My scanner is reading 3.4. Lol. If it’s a nice day where you live, have a 99, a 2.7, scanner and a couple minutes to help me out please see what your maf is reading. I will send you a Dunkin’ card. Thanks
  9. Feb 29, 2020 at 8:48 AM
    Rachelsdaddy
    Southern NH
    Mine doesn’t whistle when going down the road , or did you put some FlexTape over the hole already... lol, smaht ass
  10. Feb 29, 2020 at 9:05 AM
    Black DOG Lila
    Virginia
    It's on my to do list for the wet carpet fix:thumbsup: Rubber floormat on passenger side delete mod for now keeps it dry till I can find a screwdriver:D
    I just turn up the radio for Taco whistle drown out mod:rofl::rofl:
  11. Feb 29, 2020 at 9:11 AM
    Black DOG Lila
    Virginia
    Do you think the whistle and drip are related? Would be nice to fix both with flex tape once I find a screwdriver.
  12. Feb 29, 2020 at 9:17 AM
    Black DOG Lila
    Virginia
    Make it a case of BJs and I'll bring full diagnostics immediately:thumbsup:
    Can't eat donuts got Sugarbeadies. Sickashellnemia and HPV2
  13. Feb 29, 2020 at 9:28 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I read mine in cfm..I think. I don't think it's going to match the liter of the engine.
  14. Feb 29, 2020 at 9:31 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mine read somewhere from 3.3-3.6 at idle. It's fine
  15. Feb 29, 2020 at 9:54 AM
    Rachelsdaddy
    Southern NH
    Bummer. Thanks
  16. Feb 29, 2020 at 10:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am curious how a mass and weight label is used to measure volume Looking to learn something new !!
    Kristi with a K and Speedytech7 like this.
  17. Feb 29, 2020 at 6:15 PM
    Glamisman
    the "perfect" ratio of air to fuel is apx 14.7 to 1. So many grams of air per second equals so much weight then the PCM calculates fuel based on that, modified by air temp, throttle position etc.etc.
