MAF Sensor Cleaning..
Discussion in '1st Gen. Tacomas (1995-2004)' started by eric70412, Feb 5, 2009.
  1. Jan 20, 2016 at 8:53 AM
    #41
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    I did but just a little as it didn't really feel right to me but I didn't touch anything with the straw. Did you notice any performance increase? My truck feels like it's running a little stronger but that might just be my imagination telling me it should feel better.
  2. Jan 20, 2016 at 8:59 AM
    #42
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    For me, my idle seems smoother. The truck has a smoother feel under load as well. Throttle response feels better too, but that's probably just placebo. But who knows... the can says "+4-10HP to the wheels!" I'm guessing it's probably around 4 HP haha
  3. Jan 20, 2016 at 9:56 AM
    #43
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    FWIW that bulb is the "intake air temp" sensor, the MAF is up inside the tube.
    The "delicate looking resistors" is the MAF sensor.
    microsnook, burntkat and johnny3 like this.
  4. Jan 20, 2016 at 10:58 AM
    #44
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Haha hmm well that's good to know!
  5. Jan 20, 2016 at 12:51 PM
    #45
    boostd4
    boostd4 Member
    Makes sense to disconnect the battery after cleaning or replacing the MAF to reset the STFT and LTFT values. Probably wouldn't hurt to do this regularly anyway to make sure everything else is working fine.
  6. Jan 20, 2016 at 1:36 PM
    #46
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Dang..good to know..Thanks, just thought I cleaned mine,,gotta do it again.
    robertjohnsonjr likes this.
  7. Jan 20, 2016 at 1:53 PM
    #47
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    or pull the EFI fuse so you don't have to reset your radio.
  8. Jan 20, 2016 at 3:53 PM
    #48
    Dilleytech
    Jakob
    07 AC SR5 4x4
    The video on the first page shows the bulb to be the airflow sensors not the resistors... This makes more sense to me as that's where it could read air flow.. Is there anything to back up your point? Just to clarify
  9. Jan 20, 2016 at 4:10 PM
    #49
    Dirty Pool
    99 XCAB V6 MT TRD
    The video is wrong, common knowledge. Go back and watch at 2:58. The sensor mentioned in the blue caption box is the MAF sensor. If you need more, consult the factory service manual for drawings.
    Dilleytech[QUOTED] likes this.
  10. Jan 20, 2016 at 4:16 PM
    #50
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Gotcha, I missed that.
  11. Jan 20, 2016 at 9:37 PM
    #51
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Know what? I'm sarting to think there's no point to resetting the fuel trims. LTFT recalibrates within minutes or less as you drive. and STFT never saves any values anyways.
    its probably wiser to just keep everything the way it was so you don't have to re run all the monitors which can take 200 miles. relearning the LTFT takes maybe 5.
    Aldog likes this.
  12. Feb 18, 2016 at 12:04 PM
    #52
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Update: 4 months later it's still running well, but there was no improvement to mpg. Still trying to figure out why I'm only averaging 14.1 around town.
  13. Feb 18, 2016 at 12:33 PM
    #53
    CodeSeven
    Serge.
    Coachella Valley
    Heavy foot. Heavy truck. lots of air resistance. Changing gears at too high of an rpm. Need engine, transmission, and/or gear oil change. Dont go faster than 70 on the freeways
    And i think 14/17 is suppoed to be what we get
    BandanaBerg likes this.
  14. Feb 18, 2016 at 1:37 PM
    #54
    RyanL
    Indiana
    Thanks for the tips. For 4 years I got 16.5 on every tank & haven't changed how/where I drive since. About 2 years ago it started dropping. I've flushed the trans, keep the engine oil fresh, rear diff is in good shape too.
    But <70 freeway, now you're asking too much!
  15. Feb 18, 2016 at 6:52 PM
    #55
    CodeSeven
    Serge.
    Coachella Valley
    check your ECU readings. make sure that's all running properly
  16. Oct 3, 2016 at 6:48 PM
    #56
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    How does one check their ecu readings?
  17. Oct 3, 2016 at 7:23 PM
    #57
    CodeSeven
    Serge.
    Coachella Valley
    get a scanner that displays live data
  18. Oct 3, 2016 at 7:36 PM
    #58
    EB Group
    Rudy
    Halifax
    Ok, good call. Like an Ultragauge
  19. Apr 3, 2017 at 5:56 PM
    #59
    VABOWHUNT
    VABOWHUNT Well-Known Member
    Richard
    Virginia
    2013 Double Cab Short Bed
    20×9 Fuel Anza's, 295/50/20 Nitto Trail Grapplers, Toytec Ultimate Lift, 20"Rigid Industries SR Hybrid Light & Grill Combo, K&N Cold Air Intake, Air Raid Throttle Body Spacer, Magna Flow Performance Exhaust, Body Armor Slider/Step Rails with Light Kit, Body Armor Back Bumper with Swing Gate and matching spare.
    Well I wish I would have read through this thread before I pulled my MAS and cleaned it and my K&N air filter. Apperntly I really only cleaned the temp bulb.
    I did see the other two resists in the black housing. But they didn't look dirty at all. But I did disconnect the plug from the sensor. I did not disconnect the battery though because I wasn't sure how that would have effected my Bully Dog GT Tuner (possible program reset). Should I pull the EFI fuse before I try to start the truck or am I OK without it?
  20. Jun 30, 2017 at 1:08 AM
    #60
    QToTa
    QToTa New Member
    thank you to all posting this fix.
    i did it and taco is doing good again.
    i do have to pull the battery terminal to reset the check engine light.
