Magnaflow Cat back 16625
Discussion in '4 Cylinder' started by arlypoo, Apr 20, 2012.
  1. Apr 20, 2012 at 4:37 PM
    arlypoo
    arlypoo [OP] Well-Known Member
    Arlin
    Port Something
    2005 2.7 4x4
    Went to install the exhaust but this part is about 5 inches too long.
    Called magnaflow and they say this catback system doesnt fit my truck, but that's not what they said in the email prior to purchasing the item.
    My options are: A) Return the item and take their 15% restocking hit, or
    B) Get a shop to fab it 5 inches back, and void the warranty
    Help me decide!
    By the way the truck is a 2005 2.7L extended cab 4x4(I mentioned this when I ordered it)
  2. Apr 20, 2012 at 6:12 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    take it to muffler shop
  3. Apr 21, 2012 at 4:51 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    it doesnt matter if its a 2.7 or a 4L motor, but the 4 door and extended cab exhausts are different. Probably got the wrong one or the wrong one was sent?
  4. Apr 21, 2012 at 5:11 AM
    arlypoo
    Arlin
    Port Something
    2005 2.7 4x4
    They say it's for an ext cab with a 5 foot box so I am assuming that's the 2wd model. The employee I spoke to on the phone says that they do not make a cat back for an ext cab with a 6 foot bed.I was under the impression that they didnt make an extended cab with a short bed. Either way it doesnt make sense to me how it would be longer but it's built for a shorter bed?
    something fishy here...
  5. Apr 21, 2012 at 5:16 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    thats true, jut do a bit of research and compare to your stock and see what you come up with.
  6. Apr 21, 2012 at 5:44 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Definitely fishy. That exhaust is the only exhaust listed on their website for the 4 banger. There is no 5 foot bed on the extended cab. They only come with the 6 foot bed.
    Magnaflow's Description of part no 16625
    It's not uncommon for things that fit the extended cabs will also fit the double cab short beds. I'm wondering if they sent you one for the double cab long bed by mistake. I'd try to make them replace it and foot the shipping for the replacement if they screwed up. However, it would probably be cheaper to just have an exhaust shop cut it down and weld the muffler in at the same time.
  7. Apr 21, 2012 at 11:25 AM
    arlypoo
    Arlin
    Port Something
    2005 2.7 4x4
    Just took that piece to a muffler shop and had it shortened.
    Problem solved.
  8. Dec 18, 2016 at 11:53 AM
    agolden23
    agolden23 Member
    Anthony
    2006 Tacoma TRD Access Cab, 6 Speed, Stock
    2016 TRD Pro Wheels and Tires, Otherwise Stock
    Old post I know, but any idea what it should cost to cut and reweld this pipe?
