Magnetic Transfer Case Drain Plugs
Discussion in 'Trail Toys' started by SMKYTXN, Jul 28, 2018.
  1. Jul 28, 2018 at 10:49 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    So who else was surprised to not see a magnet on the transfer case drain plug? I certainly was. I for one want the peace of mind of seeing a clean magnet when I change the fluid in the tcase.
    So...let's solve that problem. Trail Toys is now offering a replacement magnetic drain plug for the low low price of $8.50 each. :D You also have the option of picking up extra copper washers during checkout.
    The drain plugs fit all 1st and 2nd gen Tacomas, FJ Cruisers, and 4Runners. The plugs will fit all gear driven transfer cases as well, but they come with a magnetic plug. If you need a replacement this will work just fine.
    You can see the stock drain plug below with the 21mm head and the lack of a magnet. The new plugs have a taller 19mm that will reduce the risk of rounding off the hex.
    Click here to buy now
  2. Jul 30, 2018 at 2:12 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Do need! Will be an order from me in the near future.
    SMKYTXN[OP] likes this.
  3. Jul 30, 2018 at 2:28 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yup, this is an easy one to cross off the mod list.
    Slashaar[QUOTED] likes this.
  4. Aug 1, 2018 at 4:25 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Bump! Have you picked up your new transfer case drain plug yet?
    Slashaar likes this.
  5. Aug 1, 2018 at 5:26 PM
    Slashaar
    Josh
    Kansas City, MO
  6. Aug 1, 2018 at 5:30 PM
    Slashaar
    Josh
    Kansas City, MO
    They fit 3rd gens right?
  7. Aug 1, 2018 at 5:33 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Correct, though I haven't pulled the plug on a third gen to see if Toyota has added a magnet or not. I'll send you a refund if there's a magnet in the 3rd gen case, just let me know.
    TRDSport10 and Slashaar[QUOTED] like this.
  8. Aug 1, 2018 at 6:51 PM
    Slashaar
    Josh
    Kansas City, MO
    Just making sure. I have a 2nd gen, but @Sociopenguin has a 3rd.
    SMKYTXN[QUOTED][OP] likes this.
  9. Sep 1, 2018 at 8:59 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Which rear diffs does this fit?
  10. Sep 1, 2018 at 9:40 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    All of the 8” toy rear ends. The only thing I haven’t checked to see is if the flange on my plug is too large in diameter.
    My old rear axle is at a buddies house. I plan on stopping over tomorrow to check the fitment.
  11. May 6, 2019 at 10:34 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    You still selling these?
  12. May 6, 2019 at 10:36 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Will these fit the 8.75 rear ends? (3rd gen if it matters)
  13. May 6, 2019 at 10:38 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yes, they're available on the website.
    https://trailtoys.net/products/magnetic-drain-plug
    Yes they should fit just fine.
  14. May 6, 2019 at 10:39 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    What is the lead time?
  15. May 6, 2019 at 10:45 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Order now and they'll ship in the next hour.
  16. May 6, 2019 at 10:56 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    THANK YOU!
    Your order number is: R362678864
    Done
  17. May 11, 2019 at 10:01 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Got my case plugs yesterday. Thank you for the quick turn around time. I’m in need of changing fluids so this came along at the perfect time for me.
    TRDSport10 and SMKYTXN[OP] like this.
  18. May 11, 2019 at 10:02 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Good deal. Let me know if you have any issues with them.
    Ace115[QUOTED] likes this.
  19. May 11, 2019 at 10:02 PM
    1997tacomav6
    Denver
    Excellent, I will be ordering two.
    Does the OEM washer for oil changes work?
    Or you need to buy specific washers from them?
  20. May 11, 2019 at 11:10 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Each plug is supplied with a copper washer and you can buy extras on the site when you place your order.
    1997tacomav6[QUOTED] likes this.
