Magnetic Transfer Case Drain Plugs
Discussion in 'Trail Toys' started by SMKYTXN, Jul 28, 2018.
  1. May 12, 2019 at 6:26 AM
    1997tacomav6
    Denver
    Ok so I drive like 30-40k a year depending, so that’s like 8 oil changes a year.
    I think the OEM washer gets replaced every time I get an oil change in that it’s a crush washer I think.
    So do these need to be replaced every oil change? Or can the dealership use the OEM washer when they do my oil change?
  2. May 12, 2019 at 6:34 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    According to Toyota yes they do. Do I replace mine every time, no. I have a few in the garage and do replace them now and then...when I remember. :)
    1997tacomav6[QUOTED] likes this.
  3. May 12, 2019 at 6:37 AM
    1997tacomav6
    Denver
    So the dealer washer can be used for this plug I’m guessing too?
  4. May 12, 2019 at 7:14 AM
    1997tacomav6
    Denver
    Ok,great.
    No ezview mirrors for the 2004 tacoma?
  5. May 12, 2019 at 7:18 AM
    1997tacomav6
    Denver
    Are the drain plugs the same size for the engine and transfer case and manual transmission?
    I pretty sure none of mine are magnetic.
    So maybe I need three
    Bikinaz[QUOTED] likes this.
  6. May 12, 2019 at 7:23 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I would think so. I'm not an expert but I've used washers from various places with the stock plugs. I'm also an old cheap bastard so I've only bought one thing from the dealership. Remember, washers aren't rocket science...unless they're on a rocket.
  7. May 12, 2019 at 7:26 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    When in doubt try this. I have this set for my upcoming change on my truck. I did my wife's Sequoia a while back and did not replace the washers. No leaks on hers, but next time I'll probably replace the washers.
    https://www.amazon.com/GENUINE-TOYOTA-TRANSFER-DIFFERENTIAL-SERVICE/dp/B017V4BAXI
    Also I use easy drain valves for oil changes so no more washers there.
    SandyTaco4x4 likes this.
  8. May 12, 2019 at 9:20 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The transfer case and rear diff are the same thread pitch. The manual transmission and oil pan plugs are a different size, but should be magnetic from the factory.
  9. May 23, 2019 at 6:34 AM
    1997tacomav6
    Denver
    Does the easy valve have a magnet on it?
    Where did you get yours from?
  10. May 23, 2019 at 10:05 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
  11. Aug 26, 2020 at 8:38 AM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Does it also fit 3rd gen Tacoma?
  12. Aug 26, 2020 at 9:24 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Says on website it fits 2005 to current.
    I'm glad you brought this thread back and I saw it. About to do my fluid change soon anyways
  13. Aug 26, 2020 at 9:27 AM
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    Yeah saw that. I guess I wanted to hear from OP due to main post not mentioning it. I'll go ahead order it.
    "The drain plugs fit all 1st and 2nd gen Tacomas, FJ Cruisers, and 4Runners."
  14. Aug 30, 2020 at 4:06 AM
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    Does aluminum oem washer fits with this drain plug? I believe transfer case is aluminum and you should use aluminum washer. Correct me if I’m wrong thanks!
  15. Nov 17, 2023 at 11:50 AM
    #35
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    I tried to place an order. How long are the Magnetic Transfer Case Drain Plugs on back order?
  16. Nov 17, 2023 at 12:46 PM
    #36
    SMKYTXN
    Nathan
    Houston
    DCFB
    They're in stock, just not updated on the site. Your order will ship next week.
  17. Nov 17, 2023 at 12:59 PM
    #37
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Oh sweet I never thought about this (haven't changed most of my fluids yet). Ordered 2 for my 21. :thumbsup:
    SMKYTXN[OP] likes this.
  18. May 29, 2025 at 8:59 AM
    #38
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Bumping this thread for a nice product. I finally needed to service my diffs and transfer case, and I can confirm the transfer case did not have a magnet in the fill plug. I remembered I grabbed this a while back and I threw it on when I sealed up the TC. It threaded on beautifully. This also fits in the fill plugs in both diffs, but the OEM bolts have magnets for those already so I kept them. It's nice to have an easily accessible magnet in the TC for a quick health check when doing future services now.
